    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    TSS has changed dramatically in last few weeks
    Scheduled Pinned Locked Moved Suunto Vertical
    9 Posts 7 Posters 775 Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      kludwig
      My calculated TSS’s have gone down dramatically in the last few weeks. For the same exercise, despite similar heart rate and time of exercise, the TSS has gone down by about half. Either the old ones were way too high or the new ones are way too low. Anyone else have this problem lately?
      S SportsfreundS Brad_OlwinB 3 Replies Last reply Reply Quote 1
      • S Online
        Stavrogin @kludwig
        @kludwig Have you checked your zones were not changed during an update?
        You can also check it against a free TrainingPeaks account.
        Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
        Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
        Coros: Pace Pro, Apex 4
        • SportsfreundS Offline
          Sportsfreund Bronze Member @kludwig
          @kludwig Same here. I can more and more sports but it goes down.
          But tomorrow my vertical 2 will arrive. I’ll see if it’s different there.
          • H Offline
            hamdas34
            Same here. Suunto support confirmed that they are working on the issue. Hoping this will be fixed in next updates.
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @kludwig
              @kludwig check HR, power and pace zones.
              Vector/T6c/Vertical 2 Ti
              sky-runnerS 1 Reply Last reply Reply Quote 0
              • sky-runnerS Offline
                sky-runner Platinum Member @Brad_Olwin
                @Brad_Olwin said in TSS has changed dramatically in last few weeks:
                I wonder how one is supposed to know what their power zones are? Most people know how to figure out their HR zones, although many still do it incorrectly. Pace zones are more difficult but can be derived from race results or a lactate threshold test. Personally I wouldn’t know if I didn’t have my lactate threshold pace from Garmin. But power zones? No idea at all how to get these right?
                I think if Suunto algorithms depend on zones so much, there has to be a guided test in the watch to calculate the zones - a guided test that does everything end to end, including updating the times.
                Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                jjpazJ Brad_OlwinB 2 Replies Last reply Reply Quote 0
                • jjpazJ Online
                  jjpaz Bronze Member @sky-runner
                  @sky-runner said in TSS has changed dramatically in last few weeks:
                  I’ve updated my power zones using my last 10K Race (december) data amd using a external tool. Now the 3 zones are more aligned for flat running (in trail running pace will differ).
                  Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                    sky-runner Platinum Member @jjpaz
                    @jjpaz I use TSS® for trail running all the time, and that seems to produce results consistent with TSS(hr).
                    In fact my TSS® values tend to be a bit higher. That makes me think that grade adjusted pace (NGP) is actually used in relation to pace zones when it comes to calculating TSS.
                    I tend to ignore power zones because I am not used to them and as I don’t know how to calibrate them. And from what I know running power numbers vary a lot from rand to brand, which makes me not trust it. It has been at least a decade since I’ve run a road race. I guess I could look at some threshold efforts to see where my power stabilizes. That works be close to the threshold power.
                      Brad_Olwin Moderator @sky-runner
                      @sky-runner Just use a run where you had an LT interval (Tempo) or more than one. That will provide a reasonable estimate of Threshold power. You can then use an online tool to calculate. I use TrainingPeaks.
                      I tend to use Power as my intensity zone for Running Interval workouts (these are above LT) that are no longer than 3 min where HR is useless. I am fairly good with RPE but having a power zone set can keep me from going to hard on the first interval and slowing down on the last. NGP will do the same but we cannot set NGP as an intensity zone.
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
