    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Watches
    40 Posts 11 Posters 7.7k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Horizontal_2H Offline
      Horizontal_2 Bronze Member @gkaempfer
      @gkaempfer That’s better than advertised. A 14 days-cycle could be accomplished with 20 hours of GPS.
      Is this with the best settings and OHR 24/7 on?
      G 1 Reply Last reply Reply Quote 0
      • G Offline
        gkaempfer Bronze Member @Horizontal_2
        @Horizontal_2 Indeed better than advertised!
        AOD OFF
        Raise to wake: Display only
        247 HRM
        Notifications ON
        No external BT connections except Android Suunto App
        Wireless OFF
        BT discovery OFF
        Brightness LOW
        DND from 22:00-5:40
        Sleep tracking on with HRV but without SPO2
        Some navigation but not during most of the activities (maybe during some 7 activities of about an hour each - easy navigation).
        No use of any SuuntoPlus Apps
        NO USE OF FLASHLIGHT
        G Horizontal_2H 2 Replies Last reply Reply Quote 0
        • G Offline
          gkaempfer Bronze Member @gkaempfer
          Note that I did run down the battery all the way to 3% before recharging (ran a marathon in the last activity beginning with 8% or so).
          It may need to be counted as 13.5 days because I took the watch off the charger at 19:00 and put it on the charger on the 14th day at around noon (so maybe 7 hours before the full 14 days). However, the remaining 3% would have brought me there easily.
          • sky-runnerS Offline
            sky-runner Platinum Member @segi_pn
            And now I am experiencing an extreme battery drain with Race S.
            Yesterday while I was at work it entered an extreme power save mode with 3% remaining, but still shut down a couple of hours later. I recharged it to 92% at around 8 pm last night. This morning, 12 hours later, it is already at 53%. No activities in between!
            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
            Horizontal_2H 1 Reply Last reply Reply Quote 2
              @gkaempfer Thanks. I’m similair. It’s a bizarre result. Congratulations on your watch. Suunto did a great job with yours 🙂
              I’ve just turned off the SPO2. Can’t imagine that’ll do tricks, but we’ll see. I do use the flashlight. Only a few seconds per day.
                Horizontal_2 Bronze Member @sky-runner
                @sky-runner That’s really weird. Does it happen often?
                sky-runnerS 1 Reply Last reply Reply Quote 0
                • 2 Offline
                  2b2bff Gold Members
                  My Race S drains possibly a bit quicker, but not by a huge amount. I charged it Monday in the evening and now it is at 74% including about an hour of GPS tracking…
                  Suunto Race S
                  Garmin Epix Pro
                    sky-runner Platinum Member @Horizontal_2
                    @Horizontal_2 It happened once in the past last year and now was the second time. The rapid discharge has stopped once I’ve recorded an activity - a run.
                    segi_pnS 1 Reply Last reply Reply Quote 0
                    • segi_pnS Offline
                      segi_pn Bronze Member @sky-runner
                      @sky-runner Do you use an HR belt?
                      Suunto Core (17y)
                      Suunto Vertical Ti
                      • safariS Offline
                        safari
                        I can say this clearly; I don’t need any extensive testing, I’ve been using Sunto Vertical Titanium Solar for a year and a half. After the last firmware update, I started carrying my charging cable with me. Besides, my sports activities have decreased due to winter, I only use it daily. Now my charging cycle has dropped to once every 6 days.
                        history:
                        Suunto Vertical 2 titanium Black
                        suunto vertical solar titanium
                        suunto 9 baro
                        suunto ambit 3
                        suunto ambit 2
                        Suunto Heart Rate Belt
                        Suunto Smart Heart Rate Belt
                        suunto App: apple iphone 14 pro
                        F cosme.costaC 2 Replies Last reply Reply Quote 2
                        • F Offline
                          fedequei @safari
                          @safari I agree 100%, we need a fix for this
                          • cosme.costaC Offline
                            cosme.costa @safari
                            @safari I’m using a SVTS, backlight, raise to wake and notifications are off. I’m doing around 4 GPS hors per week plus two hours without GPS and i recharge it evry two and a half weeks, if I shut down 24/7 and sleep tracking I get a week more.
                            So, 6 days it is not normal and not related to the last firmware. Do you have backlight or raise two wacke activated? Do you get hundreds of notifications per day? Did you tried to perform a softreset?
                            safariS 1 Reply Last reply Reply Quote 1
                              @segi_pn said in Battery drain:
                              Yes, two different external HR sensors connected to the watch - Suunto HR sensor and Coros Armband HR sensor.
                              And yes, when I had a similar issue in the past it was likely caused by the external HR sensor. But what is interesting and different in this case is that the rapid discharge has happened after the watch battery got fully discharged and the watch turned off, then I charged the batter and didn’t have any activities.
                                Hi!
                                Back again 🙂
                                So, this was a wonderful cycle. It was like the Vertical 2 knew I was logging the drain. It was spot on.
                                Results:
                                • 100% to 12%
                                • Almost 14 days.
                                • 15,5 h of GPS (the first big activity was skiing. The rest was running, sometimes with maps)
                                This is what I changed since the last time, where the drain was too high:
                                • No SPO2. I don’t even know how to interpreted the data, so why measure
                                • No use of SuuntoPlus Apps during activities.
                                Still want to know what the effect of the H10 will be, but I’m actually pretty happy with the HR measurements from wrist.
                                segi_pnS 1 Reply Last reply Reply Quote 1
                                • segi_pnS Offline
                                  segi_pn Bronze Member @Horizontal_2
                                  @Horizontal_2
                                  This is my last cycle. The next day, I downloaded the map without charging.
                                  Suunto Core (17y)
                                  Suunto Vertical Ti
                                  Horizontal_2H 1 Reply Last reply Reply Quote 1
                                    Horizontal_2 Bronze Member @segi_pn
                                    @segi_pn Thanks! So, still a sharp discharge at the first ~10%?
                                    Seems overall better than before? Are you statisfied? For how long do you have the Vertical by the way?
                                    • safariS Offline
                                      safari @cosme.costa
                                      @cosme.costa
                                      I’ve done a soft reset a few times. It hasn’t helped much.
                                      My watch is used daily without any activity being activated.
                                      HR tracking and notifications are on. I wear it on my wrist at night.
                                      Wrist wake-up is on, high.
                                      Screen brightness is medium.
                                      Notifications are on.
                                      I manually sync with my phone 2-3 times a day.
                                      The watch face is athletic.
                                      Daily alarm is on and rings every morning.
                                      These are the things that come to mind.
                                      It’s 100% charged on Monday and drops to 47% on Thursday.
                                      history:
                                      suunto 9 baro
                                      suunto ambit 3
                                      suunto ambit 2
                                      cosme.costaC Ecki D.E 2 Replies Last reply Reply Quote 0
                                        cosme.costa @safari
                                        @safari Shut down wrist wake-up…In my experience this is a killer, it enables the backlight even during the day so the battery consumption is very high.
                                        Anyway, with your configuration, I would expect this battery drain, nothing too strange.
                                        • Ecki D.E Offline
                                          Ecki D. Bronze Member @safari
                                          @safari in your iPhone do you have Settings > General > Background App Refresh for the Suunto app disabled.
                                          I did see more battery drain when this was on.
                                          https://www.strava.com/athletes/37982563
                                          https://www.instagram.com/macdev
                                          • segi_pnS Offline
                                            @Horizontal_2
                                            That initial steep decline is probably related to charging without charging.
                                            The current cycle does not show a similar steep discharge at the beginning.
                                            Basically, I am currently satisfied with the consumption/battery life of the watch.
                                            I have had the watch for 1 year, but it was purchased second-hand. The original owner claimed that he had only used the watch for a few months.
                                            Suunto Core (17y)
                                            Suunto Vertical Ti
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
