    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Vertical 2 resources
    Scheduled Pinned Locked Moved Suunto Vertical 2
    59 Posts 12 Posters 10.3k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • masi0M Offline
      masi0 @Manuel Extreme
      @Manuel-Extreme In the night yes, but not during the day.
      Manuel ExtremeM 1 Reply Last reply Reply Quote 0
      • Manuel ExtremeM Offline
        Manuel Extreme Silver Members @masi0
        @masi0 From in-app documentation, there’s no clear distinction between daytime and nighttime HRV measurement.
        What is explicitly described is how “resources” are calculated:
        Active state: recovery time from activities reflects recovery needs. Longer recovery times indicate faster depletion of resources.
        Inactive state: HRV is used to assess autonomic balance. Higher HRV indicates more available resources, while lower HRV indicates reduced resources. Metrics like RMSSD, stress index, SDNN, together with heart rate, are used to evaluate stress levels.
        So the focus is not on when HRV is measured, but on how it is used within the model.
        Vertical 2 v2.56.18
        • M Offline
          maszop Bronze Member @Manuel Extreme
          @Manuel-Extreme HRV is only measured during the sleep portion of the day. It’s not measured during the day, which wouldn’t make much sense anyway.
            Manuel Extreme Silver Members @maszop
            @maszop Are you saying that based on inference, or because you have the specifications?
            Vertical 2 v2.56.18
            • M Offline
              @Manuel-Extreme said in Vertical 2 resources:
              “Suunto Race, Suunto Race S, Suunto Vertical, Suunto Ocean and Suunto 9 Peak Pro GPS watches can track your HRV during your sleep. Nighttime measurement is a reliable and easy way to gather comparable HRV data.”
              https://www.suunto.com/en-ie/sports/News-Articles-container-page/how-to-use-hrv-to-optimize-your-recovery/
              SquirrelS Manuel ExtremeM 2 Replies Last reply Reply Quote 0
              • SquirrelS Offline
                Squirrel Silver Members @maszop
                Looks like this debate is going nowhere. @maszop in the picture above, you show HRV widget that shows average HRV during sleep specifically. But it does not disprove that 24 hour HRV measurement is part of the data stream used for continuous Resources calculation. So better arguments are needed. Or better yet, someone from Suunto who knows what they are talking about regarding this, to set the record straight.
                @masi0 said in Vertical 2 resources:
                Same goes for this claim. Provide more details, or is this just an assumption?
                Race S
                • M Offline
                  maszop Bronze Member @Squirrel
                  @Squirrel Measuring HRV alone is pointless because the data itself is useless. What’s needed is a trend based on repeated measurements under repeated conditions. That is, at night.
                  SquirrelS A 2 Replies Last reply Reply Quote -1
                  • SquirrelS Offline
                    @maszop
                    Agreed, HRV in isolation. But nobody said it is used in isolation to calculate resources.
                    You already got that in the HRV widget you posted above and also in the app, where you can look at long term trends and history. So what are you trying to suggest here regarding resources?
                    Race S
                    • A Offline
                      aiv4r Silver Members @maszop
                      @maszop correct, but my assumption would be that Suunto as everybody else have added HRV during the day also since they added Stress measurment in Resources. Do not have any proof of that, but I doubt they only use HR to calculate that.
                      Suunto Race 2 (Titanium Trail)
                      Suunto Vertical (Titanium Solar Forest)
                      • M Offline
                        maszop Bronze Member @aiv4r
                        @aiv4r Your assumption is based on what?
                        A 1 Reply Last reply Reply Quote 0
                          @maszop Why do you keep insisting on answering with certainty about things you don’t actually know?
                          Stress scores are typically measured using HRV and HR, including during the day under optimal conditions.
                          That’s certainly how Firstbeat algorithms work.
                          Does Suunto do it? According to its in-app documentation, yes
                          The study confirms that other sport Watch Firstbeat based primarily uses HRV (with HR as a supporting signal) to derive the stress score.
                          https://pmc.ncbi.nlm.nih.gov/articles/PMC12647429/
                          Vertical 2 v2.56.18
                          M 1 Reply Last reply Reply Quote 1
                          • M Offline
                            @Manuel-Extreme
                            You can’t get precise data from the watch’s OHR throughout the day – data that would let you reliably determine HRV and spot trends.
                            Garmin churns out hundreds of ridiculous statistics; half of them might as well come from a random number generator.
                            https://forum.suunto.com/topic/14697/armband-and-zonesense
                            During sleep, you move your hand very little, skin temperature remains relatively stable, and blood flow is more consistent, making this type of measurement relatively easy for optical heart rate (OHR) sensors.
                            And apart from the measurement problem during the day, there are also hundreds of factors that affect the body, that affect HRV, and have nothing to do with recovery.
                            Manuel ExtremeM 2 2 Replies Last reply Reply Quote -1
                              @maszop You keep writing your own interpretations that have little to do with reality. But that’s fine, I won’t insist, because I understand that I could bring all the documents and data, and you would still remain faithful to your own ideas without giving value to the topic
                              Vertical 2 v2.56.18
                              • M Offline
                                @Manuel-Extreme Find one place where Suunto says it uses HRV during the day for Regeneration and Resources. For now, you’re creating some kind of alternative reality.
                                GiPFELKiNDG 2 Replies Last reply Reply Quote -1
                                • GiPFELKiNDG Offline
                                  GiPFELKiND Silver Members @maszop
                                  @maszop Screenshot comes! One Moment please
                                  If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                    @maszop here you have the answer. Sure suunto uses HRV for Ressourcen Management in day conditions.
                                    • A Offline
                                      @maszop based on the description under resources. The screenshot is already here in the thread. I agree with you that it does not makes sense, but Suunto also sometimes does things that do not make a lot of sense 🙂
                                      • 2 Offline
                                        2b2bff Gold Members @maszop
                                        @maszop said in Vertical 2 resources:
                                        I guess therefore it is only used by resources in the “inactive” section…
                                        Suunto Race S
                                        Garmin Epix Pro
                                        • M Offline
                                          @aiv4r I haven’t seen this before. If this is true, then this Resources widget is probably not very reliable.
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
