    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ressourcen Widget Problem wrong calculation.
    Scheduled Pinned Locked Moved Suunto Race 2
    3 Posts 3 Posters 233 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • GiPFELKiNDG Offline
      GiPFELKiND Silver Members
      Hey,
      Is the Ressourcen widget at the Vertical 2 and the Race 2 used by a new algorithm? At my older Vertical i reach often a number unser 50% and much lower. Is Sometimes after run Training at 10-20% Ressourcen left. At the new models i didnt reach numbers down as 60% . O wear both watches for measurement sometimes at both wrists. Something ist new but its bad measurement. The Algorithm at all older watches (Race 2 and Vertikal 2) is so much better. Its a shame! When i buy a newer watch then i think its Correct to make existing things wich are working fine better, but not make make this things more Bad. Noone here says Something about this! At my older wstches the Ressourcen working very fine and represented my Feeling… But now. I didnt understand why suunto make changes at working things and apps and widgets.
      No matter how good the new display and heart rate sensor are, if existing functions that were good in older models are changed and no longer work, what good is a better display if the old core functions have simply become rubbish with a new algorithm?
      anyone with same values?
      1 von 1
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
      2 1 Reply Last reply Reply Quote 0
      • 2 Offline
        2b2bff Silver Members @GiPFELKiND
        @GiPFELKiND I understand your frustration, but how many of those posts will you make?
        Suunto Race S
        Garmin Epix Pro
        • sartoricS sartoric locked this topic on
        • sartoricS Offline
          sartoric Moderator
          Closing this one to avoid duplicates.
          If you want to refer to several watch models, open the thread in the main section
          SVTS - 2.50.28
          SSSWHR BARO Amber - 2.8.32
          Samsung A5 2016 - Android 7.0
          Suunto App Android 6.7.12 beta
          Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
          • First post
            Last post
          Suunto Terms | Privacy Policy
