    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    ZoneSense bug for Runs?
    Scheduled Pinned Locked Moved Suunto Run
    11 Posts 3 Posters 1.2k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Z Offline
      zagazoo
      Hi - I have an issue with using ZoneSense on my runs
      I first of all checked this with my paired HR strap for some test Walks and it worked well - seeing it reporting after 10mins and also the ZoneSense chart appearing in the app.
      For Runs it did not work for 2 runs despite the HR strap being paired correctly and showing the Heart with strap icon. The app chart just reports Heart Rate with no option for ZoneSense.
      I then turned off the hear rate monitoring for 3 mins after recovery and then I could see ZoneSense on the watch while running but after the run I still get the chart with Heart Rate and no ZoneSense - I will now try turning off the prompt for Feeling
      Any ideas how I get this working reliably? Is this a bug?
      Cheers, Andy
      ? Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @zagazoo
        @zagazoo said in ZoneSense bug for Runs?:
        I always speak for myself, but since ZS was released on Run, it has always worked for running/indoor rowing, the most frequently used activities
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zagazoo @Guest
          @Hari-Seldon - do you have post activity heart rate and feeling enabled?
          • ? Offline
            @zagazoo yep
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @zagazoo
              @zagazoo Which firmware are you using? This should work and ZS will show only on the HR graph screen. HR will show on all other screens. Here is an example.IMG_3154.jpeg
              Vector/T6c/Vertical 2 Ti
              Z 1 Reply Last reply Reply Quote 1
              • Z Offline
                zagazoo @Brad_Olwin
                @Brad_Olwin
                Yes I do see if on the HR screen during the run but after the run is completed the App does not display ZoneSense only HR trace
                  @zagazoo The app will recalculate ZS and it may take a few minutes to do this. Are you on Android or iOS? Are you using beta or production release app? I will move this post as this is an app issue not a watch issue. My ZS is showing in iOS.
                  • Z Offline
                    zagazoo @Brad_Olwin
                    @Brad_Olwin
                    Thanks Brad - I’m on IOS app and release version but so far only two test walks have displayed. ZS
                      @Brad_Olwin
                      Can you provide an image of ZS working on your watch? You are sure the belt is connected and sending good data? I have not had a problem with this.
                      • Z Offline
                        zagazoo @Brad_Olwin
                        @Brad_Olwin
                        Am I correct that I would need to take a photo of watch whilst on a run to show this?
                        I will also try acquiring heart rate with another iOS app and take phone with me
                          @zagazoo Yep
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
