    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altimeter: issue with manual altitude setting
    Scheduled Pinned Locked Moved Suunto Run
    1 Posts 1 Posters 215 Views 1 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hello,
      I waited a while before reporting this but, afaic, the last two firmware updates cause a problem when I manually set the altitude. It is a sporadic problem, so it is not easy to identify, and unfortunately, I have not yet figured out what circumstances trigger it.
      As you can see from the video, if I try to manually set a new altitude value (139m), as soon as I confirm and return to the widget, the altitude value reverts to the previous one (108m).
      I would also add that, even though I cannot correct the altitude, it keeps working correctly if I change position.
      A soft reset always fixes the issue.
      Register Login
      • First post
        Last post
      Suunto Terms | Privacy Policy
