    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Home trainer distance
    Scheduled Pinned Locked Moved Suunto Race 2
    5 Posts 3 Posters 657 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JosaipluJ Offline
      Josaiplu Silver Members
      Hi guys
      I usually use my wahoo kickr core HT with my whoosh and then sync using RunGap to suunto
      However today I wanted to do a dual record so I had :
      Kickr core paired to watch and Mac app for mywhossh
      Race 2 use hr from belt
      App use hr from coros hr
      Works well I got power on the watch but no distance
      I had to define the distance in the activity summary
      When I try to calibrate the pod it fail
      Is there a way to calibrate wheel circumference in order to have the distance recorded ?
      Old: SV, SR
      Currently enjoying race 2, wife on SRs
      S 1 Reply Last reply Reply Quote 0
      • S Offline
        Sixeela29 @Josaiplu
        @Josaiplu exactement le même problème avec ma Suunto race S et mon home traîner Elite suito
        JosaipluJ 1 Reply Last reply Reply Quote 0
        • JosaipluJ Offline
          Josaiplu Silver Members @Sixeela29
          @Sixeela29 ok donc ça viendrait pas du kickr, merci, je vais continuer avec mywhoosh et rungap alors mais je voulais tester zone sense en vélo voir l impact sur la détection des seuils
          Old: SV, SR
          • dani_degiD Offline
            dani_degi
            i do ZWIFT indoor and upload in Strava…
            i use the Race 2 as second for the SUUNTO app…
            after dooing Zwift ride u have to put the KILOMETERs manually into the app Activity “indoor cycling”…
            the INFO “Hight Meters” left in “indoor cycling” activity in the app…
            #speedup #race2 #karoo3
            Triathlon und Trailrunning 👿
            • JosaipluJ Offline
              Josaiplu Silver Members @dani_degi
              @dani_degi Yep I was expecting to be able to calibrate the HT to avoid entering the distance, but in any case it is not the way I use my HT now, I import my activity from my app into suunto and correct the TSS value using the one from Training peaks (as imported app did not use the zone to calculate TSS)
              I prefer this way in order to have also elevation data in the activity
              Old: SV, SR
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
