    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    ZoneSense + Garmin HRM Pro
    Scheduled Pinned Locked Moved Suunto Race 2
    19 Posts 9 Posters 1.8k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      I’ve had the watch for four weeks now and have already done several runs. Today was my first run where I wanted to test ZoneSense. I’m using the Garmin HRM Pro Premium chest strap and didn’t receive any data during the entire run. Is the strap not suitable for this?
      tm3610T A Brad_OlwinB BelialB 5 Replies Last reply Reply Quote 0
      • tm3610T Offline
        tm3610 @Guest
        @SyntaxError do you mean HMR Pro Plus? It tracks more data than a standard HRM. I had used Polar watches before this and my HRM Pro Plus couldn’t be used. It is likely the same for Suunto watches.
        • tm3610T Offline
          tm3610 @Guest
          @SyntaxError however, check this thread: https://forum.suunto.com/topic/11753/zonesense-garmin-hrm-pro/8
          • ? Offline
            A Former User @tm3610
            @tm3610 said in ZoneSense + Garmin HRM Pro:
            Thx, I will give it a try
            • A Offline
              Alonzo @Guest
              @SyntaxError you installed ZoneSense+ app, didn’t you?
              • ? Offline
                A Former User @Alonzo
                @Alonz of course and it says “waiting for data”.
                • Francesco PaganoF Offline
                  Francesco Pagano Silver Members Bronze Member
                  I have Garmin HRM Pro (not plus) and it works perfectly with ZoneSense. How exactly did you set your activity? Did you enable the ZS app or just wanted to see data fields or intensity zones?
                  S9PP
                  S5
                  • ? Offline
                    A Former User @Francesco Pagano
                    @Francesco-Pagano the App ist enabled and running.
                    • Brad_OlwinB Offline
                      Brad_Olwin Moderator @Guest
                      @SyntaxError I have an HRM-Pro and it works with Zonesense
                      Vector/T6c/Vertical 2 Ti
                      • M Offline
                        MarkusG Bronze Member
                        One thing that comes to my mind: are you sure that the watch doesn’t fallback to OHR? Since the last update (I’ve a Race 1) it happened several times for me that the HRM disconnected right at the beginning. The first two times I didn’t notice (I run by power and only use ZoneSene but no absolute HR-values) but now I know better and pay close attention to it.
                        On Wednesday it happened 3 times in a row that it disconnected while changing the intensity-gauge from HR to ZoneSense.
                        At the end I gave up and just kept it at HR and it didn’t disconnect.
                        TL;DR maybe take a glimpse under the watch if the green light is off while running.
                        • ? Offline
                          A Former User @MarkusG
                          @MarkusG I made a rollback to the previous Firmware so it’s not a problem of the latest update.
                          • BelialB Offline
                            Belial @Guest
                            @SyntaxError HRM is connected to Garmin’s app and therefore blocking HRV transmission to Suunto (HR alone is being transmitted).
                            You must unpair HRM from your phone, remove it from the GC and after that ZoneSense will start working like a charm 😉
                            2 ? 2 Replies Last reply Reply Quote 1
                            • 2 Online
                              2b2bff Silver Members @Belial
                              @Belial are you sue, that r-r data isn’t transmitted anymore in that case? I used an HRM DUAL with a Garmin Watch via ANT+ and a Suunto via Bluetooth and ZoneSense worked…
                              Race S
                              BelialB 1 Reply Last reply Reply Quote 0
                              • ? Offline
                                A Former User @Belial
                                @Belial said in ZoneSense + Garmin HRM Pro:
                                That sounds plausible. I’ll test that.
                                • BelialB Offline
                                  Belial @2b2bff
                                  @2b2bff I’m sure of one thing - if HRM is connected to the phone and GC app, it doesn’t broadcast R-R. After searching through the internet I’ve found info, that R-R data in Garmin’s HRM is sent only when one BT connection is present. I haven’t tested BT and ANT+ connection simultaneously, but maybe it’s possible to function side-by-side.
                                  ZoneSense with HRM started working without any issues just after I’ve deleted phone’s BT pairing and is working till now.
                                    Brad_Olwin Moderator @Belial
                                    I don’t have Garmin Connect on my phone but I have connected the HRM-Pro to two Suunto watches (BT) and both receive R-R data and both display ZoneSense. So two R-R streams are possible.
                                    BelialB 1 Reply Last reply Reply Quote 2
                                    • BelialB Offline
                                      Belial @Brad_Olwin
                                      @Brad_Olwin Suunto Forum. I knew I’d come across this solution about a year ago somewhere in the forum - glad to see I wasn’t imagining it! 🙂
                                      If you’ve managed to connect the HRM to both watches with ZoneSense running, then it seems there’s another one of Apple’s little “features” at play. For some reason, when the HRM is also connected to the iPhone, it quietly blocks the R-R data stream.
                                      I had the same issue as Grundy82 with ZoneSense stuck on “Waiting for data,” and the only thing that helped was un-pairing the strap from my iPhone’s Bluetooth. Worked instantly - go figure! 🍏
                                      • ? Offline
                                        It worked now. I deleted the Bluetooth connection from my phone and, just to be safe, reconnected the strap to the watch.
                                        • dani_degiD Offline
                                          dani_degi
                                          i wear HRM PRO withouth problems in ZONE SENS with my Race 2…
                                          shows details after 10min running…-.
                                          more stability than the Sunnto Heart Strap… (left 3x connection… ZWIFT and running …)
                                          #speedup #race2 #karoo3
                                          Triathlon und Trailrunning 👿
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
