    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bluetooth connectivity issue with iPhone and Race 2
    Scheduled Pinned Locked Moved Suunto Race 2
    3 Posts 2 Posters 1.3k Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      fritzbt2013 Bronze Member
      I’m having trouble keeping a connection with my race 2 and iPhone Xs. Race S is fine.
      With the Race 2 I was able to pair initially, but when the connection was lost for normal reasons (such as distance) it will not reconnect.
      I tried many things (reboots, unpair, etc) and nothing appears to be working right now.
      Race S still fine and connects right away.
      “Randomly” one day I was able to pair it again. I did the firmware update. But now I’m back to not connected.
      I’m thinking the Bluetooth hardware in the watch is working intermittent and may pursue a refund. But wanted to see if there any other options first …
      L 1 Reply Last reply Reply Quote 0
      • L Offline
        larrybbaker @fritzbt2013
        @fritzbt2013 Xs is pretty old hardware - what iOS are you running? all updates installed?
        When you tried to re-pair the device did you clear all connections on the phone and the app/phone?
        Vertical Ti Solar
        Vertical 2
        Race 2
        iPhone 17 Pro
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          fritzbt2013 Bronze Member @larrybbaker
          @larrybbaker 16.6.2. Close to most recent. I’m also having same problem on newer iPad… problem is following watch.
          All cleared… Bluetooth device, mobile app, etc,
          EDIT: most likely cause of my issue turned out to be you need to wear the watch for it to connect to the phone. With the race S this is not the case. I only use the race 2 watch for activities and put it on right before I start and take it off right after. My phone is usually off during and for a short while after the activity…
          Register Login
          • First post
            Last post
          Suunto Terms | Privacy Policy
