    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    The battery on Vertical 2 is draining very quickly.
    Scheduled Pinned Locked Moved Suunto Vertical 2
    12 Posts 10 Posters 1.8k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Frederick RochetteF Offline
      Frederick Rochette Bronze Member
      Since my last 100% recharge, my SUUNTO Vertical 2 has been discharging very quickly.
      0.5% per hour without recording any activity, whereas before the last charge it was more like 0.34% per hour with at least one activity per day.
      I charged it to 100% last night at 10:30 p.m. and this morning at 6:15 a.m. it was at 95%… today at 4 p.m., it is at 89%… At this rate, it won’t even last the week. I should point out that I haven’t changed any of the settings.
      Marijus SiegelM Josef NilssonJ 2 Replies Last reply Reply Quote 0
      • Marijus SiegelM Offline
        Marijus Siegel @Frederick Rochette
        @Frederick-Rochette I did a run with red light on and performance mode. Aod off. In 54min of activity it used 15%. I’m a bit concerned.
        AudaxjoeA 1 Reply Last reply Reply Quote 0
        • Josef NilssonJ Offline
          Josef Nilsson @Frederick Rochette
          @Frederick-Rochette
          I have about the same experience.
          100% at midnight
          95% when I woke up at 6am
          89% when I got back from work at 4:30pm
          Aod on, medium brightness, 2x6min bikerides for commuting
          Notification turned on but not connected to my phone during work hours.
          I upgraded from my Garmin Fenix 6 to get better battery life, not worse…
          • Stefan KerstingS Online
            Stefan Kersting Platinum Member
            Several Vertical 1 has the same problem after the last update.
            Instagram: https://www.instagram.com/helgelandsbukken/
            https://www.instagram.com/suunto_adventures/
            IG: Helgelandsbukken, suunto_adventures
            Vimeo: vimeo.com/helgelandsbukken
            Blogg: https://turblogg.midnattsola.com
            S 1 Reply Last reply Reply Quote 1
            • S Offline
              Shrek3k @Stefan Kersting
              @Stefan-Kersting said in The battery on Vertical 2 is draining very quickly.:
              Have to confirm. My SV1 lost more than 12% while lying on my desk over night without any activity, no HR activated …
              using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
              OS - Android 16/Pixel Pro 7
              • AudaxjoeA Offline
                Audaxjoe @Marijus Siegel
                @Marijus-Siegel I’m not sure what red light on is but something is wrong. I was out for four hours yesterday, AOD on, HR via watch. I didn’t touch the screen much when out, for the whole day the watch dropped around 10%. Light levels is set to low.
                I’m guessing the watch is using around 2% during GPS activity. Maybe flicking between screen or having map active might use more.
                For reference the watch was fully charged 9 days ago, 20 hours of activities, 12 hours with GPS. Battery is at 28%.
                I do not have 24 hour HR, Sleep Tracking or similar on. Notification are on. AOD set to low and display only.
                Hopefully Suunto will identify the issue soon.
                Suunto Vertical
                Suunto 9 BARO
                Garmin Fenix 3, 5
                Suunto Vector
                Mff73M 1 Reply Last reply Reply Quote 0
                • Mff73M Online
                  Mff73 @Audaxjoe
                  @Audaxjoe said in The battery on Vertical 2 is draining very quickly.:
                  Do you have a V2?
                  If yes do you know it has a flash 💡? Including a red one 😉.
                  SSU (retired), SV1, SV2
                  Wife : S9PP
                  SA: Always the latest beta :)
                  Android + Galaxy S205G
                  • AudaxjoeA Offline
                    Audaxjoe @Mff73
                    @Mff73 yes have the V2 and V1. Still not sure what you mean you had the red light on. Like you had the torch on all the time?
                    I didn’t realise you could change colour to red ☺️
                    Suunto Vertical
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                    • grekuG Offline
                      greku Bronze Member
                      My first impression was very positive and honestly surprising. After charging to 100% and logging all my activities, the watch lasted about 10.5 days with the following settings:
                      • Always On Display (AOD)
                      • 24/7 heart rate and HRV tracking
                      • Notifications enabled
                      • Do Not Disturb (DND) from 21:45 to 6:00
                      • Average of ~1 hour of GPS activity with HR belt per day
                      However, after the second charge to 99%, the battery drain increased dramatically. Within just two days (October 18–19), the battery dropped from 99% to 78%, despite only a few short activities — mostly indoor, with a single 10-minute GPS session.
                      Vertical 2
                      SquirrelS 1 Reply Last reply Reply Quote 0
                      • SquirrelS Offline
                        Squirrel Silver Members @greku
                        @greku said in The battery on Vertical 2 is draining very quickly.:
                        Same firmware on the watch?
                        grekuG 1 Reply Last reply Reply Quote 0
                        • grekuG Offline
                          greku Bronze Member @Squirrel
                          @Squirrel Yes, 2.46.12
                          Today, it’s been about 48 hours since the last charge, and I’m at 75%.
                          I think the issue might have been when it was at 99%, but I checked a few times and it never reached 100%. I had to go out, so I unplugged it.
                          J 1 Reply Last reply Reply Quote 0
                          • J Online
                            Jugger @greku
                            @greku I had same experience. Charge went up to 99% and stood there. After that in 48h it went to 81%. Then I did shut down bluetooth discovery for other devices and now after four and a half day I have 66% left. I don’t know if discovery mode have something to do with battery consumption.
                            Suunto Vertical Titanium Forest
                            Suunto Vertical 2 Titanium Sage
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
