    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Watch stuck in activity sync / "not connected" loop
    Scheduled Pinned Locked Moved Suunto Ocean
    8 Posts 4 Posters 1.4k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      garethm
      My Ocean seems to be stuck in a disconnect loop whilst syncing new activities.
      There are 3 dives logged from yesterday on the watch – it starts syncing with the app, gets about a quarter of the way through the first activity, then shows “not connected”, resets and starts again. Seems to be in an endless loop, going on for several hours now.
      Video here: movie.mp4
      For a split second before showing “not connected”, the app screen shows “watch updated needed” – however the watch is up to date, running 2.40.56. The app is up to date too from the app store (iPhone 17 Pro).
      Strangely, there was a very short auto-logged dive that did sync to the app (I have since deleted it from the watch), so a sync did work at some point yesterday. I can still see that activity.
      I’ve tried powering off the watch, and also unpaired it from the app and re-paired it, but same behaviour. Any idea how to resolve this?
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @garethm
        @garethm This is a problem specific to the iPhone 17Pro and a new BT chip. Apple states they will fix and this is an Apple issue. If you have an iPad I would sync to that temporarily and you should be fine.
        Vector/T6c/Vertical 2 Ti
        L 1 Reply Last reply Reply Quote 0
        • L Offline
          logger Bronze Member @Brad_Olwin
          @Brad_Olwin it’s happening to me too on an iPhone 17 (non-pro)
          • G Offline
            garethm
            Confirming I was able to sync succesfully after pairing the watch back with my prior device, iPhone 16 Pro.
            I will note that one very short dive (like 5 seconds) did sync via the iPhone 17 Pro. But the longer ones would not sync.
              Brad_Olwin Moderator @logger
              @logger All the 17 phones have the new chip….
              • G Offline
                garethm
                I saw the Suunto in-app message that this issue was being worked on, and subsequently that it was resolved – however I’m still unable to sync new activities to my iPhone 17 Pro. The app seems to be up to date (auto update is on, no App Store updates are showing).
                The Suunto app still resets back to the initial sync state every few minutes. It seems to be a bit less disruptive than before; the watch does not show as disconnected intermittently – but it does still reset and activities do not sync. I tried leaving it syncing for a few hours, no joy.
                I have a few scuba dives logged on the watch, followed by a hike – it never gets past 1/3 activities syncing.
                Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 0
                • Mads Hintz-MadsenM Offline
                  Mads Hintz-Madsen Silver Members @garethm
                  @garethm do you use vpn on your phone?
                  I have had issues with syncing on my Pixel phone when using vpn. Solution was to exclude the Suunto app in the vpn settings (i.e. vpn is not used for Suunto app).
                  Edit: I now read the whole thread and I realized that the issue seems to be related to latest iPhone model. Anyway, I will leave my info here in case it helps someone else.
                  G 1 Reply Last reply Reply Quote 0
                  • G Offline
                    garethm @Mads Hintz-Madsen
                    Worked it out, it’s necessary to actually update iOS to version 26.1 to fix the issue. I saw the prompt saying the issue was resolved but did not realize I wasn’t on the latest version of iOS. Watch sync is working now.
                    @Mads-Hintz-Madsen no VPN here.
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
