    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR Belt
    Scheduled Pinned Locked Moved Suunto Run
    6 Posts 4 Posters 1.0k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      Mi_chael Bronze Member
      Hi,
      My Suunto Run (fw: 3.21.14) is paired with a Suunto Smart Belt and a Polar H10 for HR belt.
      When I start an activities. What ever the type. HR belt is detected and connected with the watch.
      But when I start it the OHR continue to work instead of the HR belt.
      HR data come from the OHR not from the HR belt
      Suunto knows this issue ?
      There is a way to downgrade the firmware like a Suunto Race ?
      Thanks everyone !
      ? MiroslavaM 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Mi_chael
        @Mi_chael read this
        • MiroslavaM Online
          Miroslava @Mi_chael
          @Mi_chael turn off the heart rate measurement and the problem is solved, it will take data from the heart rate monitor. I have it turned off for sports running and trail running. I don’t have a run watch but I do have a race watch, but I think it will be the same.
          M 1 Reply Last reply Reply Quote 0
          • M Offline
            Mi_chael Bronze Member @Miroslava
            @Miroslava
            You mean in daily use or in training mode ?
            I can’t do it in training mode. Just disable the 3 min hr recovery at the end of the training.
            MiroslavaM 1 Reply Last reply Reply Quote 0
            • MiroslavaM Online
              Miroslava @Mi_chael
              @Mi_chael choose an activity, for example running, and in the exercise settings, set the heart rate from the wrist to off, so it should only take your heart rate from the chest strap. I use it like this, I have the heart rate from the wrist turned off and it only takes my heart rate from the coros hrm
              O 1 Reply Last reply Reply Quote 0
              • O Offline
                owend Bronze Member @Miroslava
                @Miroslava yeah this option isn’t there for the Run, you can’t disable OHR per exercise mode.
                @Mi_chael it sounds like it’s per design based on the post below - if you have a hr strap paired, that takes precedence and data from that will be reflected in the activity stats even though OHR appears to also be recording.
                https://forum.suunto.com/post/171418
                • System referenced this topic on
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
