    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Morning report & DND
    Scheduled Pinned Locked Moved Suunto Run
    8 Posts 4 Posters 1.5k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hi,
      It seems that the morning report disables DND (DND switch remains active though) since I updated to version 3.21.14. Has anyone else noticed this? Thanks!
      e.g.
      • DND set to 9.30PM to 8AM
      • Sleep set to 10PM to 6AM
      • These mornings I got up at 5:45AM, the report arrived shortly after, and the DND left at the same time
      ? ElmiuelE 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Guest
        Yesterday, I manually set DND mode for the entire day, and this morning, after receiving the notification report, DND mode was disabled again, but this time the switch was set to off, so I guess this is not a bug but an intentional behavior.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Guest
          @Hari-Seldon I’ll check this tonight.
          Vector/T6c/Vertical 2 Ti
          • ElmiuelE Offline
            Elmiuel @Guest
            @Hari-Seldon Hola. Lo que si he podido notar es que en mi (Vertical 2) cuando se activa o esta disponible informe matutino, no se puede accionar la linterna ni tampoco ninguna acción dada con botón. Una vez leido o anulación del informe matutino puedes accionar .
            You can even see that the flashlight is on after the report is complete or canceled. The morning report disables functions during this time.
            Sunnto VERTICAL 2
            SALUD y SENSACIONES
            • ? Offline
              A Former User @Elmiuel
              @Elmiuel said in Morning report & DND:
              even if it is somewhat related, it would be better if you published it here
              ElmiuelE 1 Reply Last reply Reply Quote 1
              • ElmiuelE Offline
                Elmiuel @Guest
                @Hari-Seldon Thanks Hari😉
                Sunnto VERTICAL 2
                SALUD y SENSACIONES
                • ? Offline
                  A Former User @Brad_Olwin
                  @Brad_Olwin Do you have any news about this? Thank you!
                  • Z Offline
                    ze230877
                    Está claro que esto es un fallo recurrente. A mí Sunnto Run con el que llevo algo más de una semana le pasa lo mismo. De 9 días he recibido el informe matinal 3 veces
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
