    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Vertical 2 watchface
    Scheduled Pinned Locked Moved Suunto Race 2
    13 Posts 9 Posters 819 Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • GiPFELKiNDG Offline
      GiPFELKiND Silver Members
      When we will geht the V2 watchface at the Suunto store?
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, 9 Baro, 9 Peak, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android🏃🏼🧗🚵
      • EgikaE Offline
        Egika Platinum Member
        Soon. .
        t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
        Jan SuchánekJ 1 Reply Last reply Reply Quote 1
        • SquirrelS Squirrel referenced this topic
        • Jan SuchánekJ Offline
          Jan Suchánek @Egika
          @Egika Any chance it will be released for Race 1 too?
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Jan Suchánek
            @Jan-Suchánek it is available for all watches that can install S+ watch faces, even the 9 Peak Pro.
            Watch: Suunto Vertical Ti
            Blog: isazi's home
            Jan SuchánekJ M OM M 3 Replies Last reply Reply Quote 2
              Jan Suchánek @isazi
              @isazi I didn´t see it. Thanks!
              • M OM Offline
                M O @isazi
                @isazi Hi, I appreciate the watchface update for other Suunto watch models. However, Ithink that the V2 watchface available as “Outback Adventure” for the Suunto Ocean is having some bugs:
                1. Instead of a white arrow on the default temperature arch below, the temperature is indicated by a black x on turquoise background.
                2. The default arch below doesn’t allow any customizing at all.
                3. The default arch on top, with sunset info, doesn’t exist at all (not visible/empty space) and can therefore not be be customized.
                4. The only window that can be customized is the default day/date window.
                My question Is this by design, or is the V2 watchface implementation buggy on the Ocean?
                KR
                MO
                • isaziI Offline
                  isazi Moderator @M O
                  @M-O Ocean firmware is older than the other watches, maybe that’s the issue. Cannot help testing because my Ocean has a newer firmware.
                  Blog: isazi's home
                  M OM 1 Reply Last reply Reply Quote 0
                  • M OM Offline
                    M O @isazi
                    @isazi Thanks for your quick reply. Could you please provide any info/timeline, if available, when the Ocean will get a firmware update in order to enable the full functionality of this watchface on the Ocean. The Ocean in general needs some love and attention as well.
                    Cheers
                    MO
                    isaziI 1 Reply Last reply Reply Quote 1
                    • isaziI Offline
                      @M-O I can’t, I only know that firmware for the Ocean is being developed
                      Blog: isazi's home
                      • A Offline
                        aerodynamik
                        This is one of the best watch faces Suunto has made. Are there plans to make it available on the Run as well?
                        • BastienhereB Offline
                          Bastienhere Bronze Member
                          Best watchface by a long stretch, well done Suunto! We need more of these with the more modern fonts and more complications.
                          One request would be UV Index data. It would be so useful and helpful, especially in countries like Australia or New Zealand! I always have to check the UV Index before my runs so I don’t burn to a crisp!
                          1 Reply Last reply Reply Quote 4
                          • M Offline
                            MartinZ @isazi
                            @isazi Hello, I have installed the V2 watchface on my Vertical 1, but due to the only one (!) possible customization, it is a big disappoitment. Is there pls any chance that will be improved in the future? Generally speaking, I would strongly welcome watchfaces similar to those of other brands (Garmin, Coros etc.), having more data available on one screen. Currently, on Vertical 1 the maximum is 7 data fields on not so nice watchface called Athletics. The rest available in the store has maximum 5 data fields or less. Are there pls any plans for widening the palette of watchfaces, satisfying also data-oriented users like me? Many thanks in advance…
                            1 Reply Last reply Reply Quote 3
                            • E Offline
                              Elipsus Silver Members
                              Installed the watchface on my 9 peak pro ! its really good, the MIP doesn’t give it much justice especially for the weather band : 463ba457-e230-4829-a4df-16213f60bacf-image.png
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
