    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SUUNTO VERTICAL does not sync with Iphone 17
    Scheduled Pinned Locked Moved Suunto Vertical
    21 Posts 8 Posters 5.8k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • FlorentinF Offline
      Florentin
      I switched from Iphone 1 Pro Max to Iphone 17 Pro Max and my Suunto veritcal does not want to stay connected to the app or to sync. I did everything, inluding a hard reset of the watch but nothing works. I can use it without problems with Iphone 16 Pro Max but not with the 17. I saw similar reports from other people on a facebook group. It is simply impossible to use the watch.
      unoczU BelialB EzioAuditoreE I 5 Replies Last reply Reply Quote 0
      • unoczU Offline
        unocz @Florentin
        @Florentin-Scarlat
        Got the same problem but no solution
        • BelialB Offline
          Belial @Florentin
          @Florentin, this issue is related to Apple’s recent WiFi/BT chip. Many users are reporting connectivity problems with CarPlay, headphones, and other devices. The problem is expected to be fixed in iOS 26.1. For now, I have to turn off background sync in SuuntoApp, as constant unsuccessful syncing was draining both the watch and the phone.
          I 1 Reply Last reply Reply Quote 0
          • EzioAuditoreE Offline
            EzioAuditore Gold Members @Florentin
            @Florentin My Race pairs and syncs fine, my Ocean disconnects all the time. Both worked fine on the 15 iPhone. There is some weird combination between devices that does this. There are another reports of iPhones 17 on the net complaining about BT/WiFi issues.
            Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
            Suunto Wing
            • I Offline
              ingoblum @Florentin
              @Florentin Same problem. iPhone 17 Pro Max Sync no possible. Yesterday Update to iOS 26.1 PB, but the same issue. On my iPad M4 with iOS 26.0 Sync works perfectly.
              • I Offline
                ingoblum @Belial
                @Belial Same issue with iOS 26.1 Public Beta.
                BelialB 1 Reply Last reply Reply Quote 0
                • BelialB Offline
                  Belial @ingoblum
                  @ingoblum that doesn’t look good 😞
                  What’s interesting, turning off the WiFi on the watch improved syncing. Activity is uploaded almost instantly but background sync-related battery draining persists.
                  • pavel.samokhaP Offline
                    pavel.samokha
                    The issue is being investigated
                    Opinions expressed are solely my own and do not express the views or opinions of my employer
                    • BelialB Offline
                      Belial @Florentin
                      @Florentin 26.0.1 released, so far so good. Sync is continuous and complete.
                      unoczU I 2 Replies Last reply Reply Quote 0
                      • unoczU Offline
                        unocz @Belial
                        @Belial
                        It still doesn’t work for me 😞
                        • BelialB Offline
                          Belial @unocz
                          @unocz after first joy, that things are working again, everything is as before. In other thread people were complaining about the similar problem - just after the update everything was working fine and then become worse 😞
                          • I Offline
                            ingoblum @Belial
                            @Belial With iOS 26.0.1 I also have the same issue. ☹️
                            • B Offline
                              bitcoin
                              @Belial said in SUUNTO VERTICAL does not sync with Iphone 17:
                              I have the same problem. I’m unable to sync my Suunto Race 2 with my new iPhone Air running iOS 26.01. Sync has been sketchy, but now it has completely stopped working. My last activity is syncing until the progress circle reaches around 70% complete before failing and retrying. I have tried everything to solve the problem locally, even resetting my iPhone’s Network Settings, without success.
                              • unoczU Offline
                                unocz
                                No change with new beta update 26.0.2
                                • unoczU Offline
                                  unocz
                                  Problem solved with iOS 26.1 beta 3
                                  BelialB B 2 Replies Last reply Reply Quote 4
                                  • BelialB Offline
                                    Belial @unocz
                                    @unocz can you please tell us something more? Is sync stable as it used to be on previous iPhones?
                                    unoczU 1 Reply Last reply Reply Quote 0
                                    • B Offline
                                      bitcoin @unocz
                                      @unocz That is good news. Thank you for sharing 🙂
                                      • unoczU Offline
                                        unocz @Belial
                                        @Belial
                                        Yes, everything works like before with the new IOS update.
                                        • I Offline
                                          ingoblum @unocz
                                          @unocz Thanks Belial. Than I´will install the Beta 3.
                                          • I Offline
                                            ingoblum
                                            With iOS 26.1 Beta 3, syncing with the iPhone 17 Pro seems to work. Hooray!
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
