Different temperature values
Hi there. I have a doubt: when I finish a race, the activity shows two different values for temperature: one inside the map and another one inside the activity.
Is it a bug or something else?
@gogapo your link doesn’t work. But the temperature inside the map is outside temperature (like if you check a weather forecast) pulled from internet, the one inside your activity is temperature measured by your watch sensor (ambient temperature + your body temperature). These are not the same.
@OutdoorMan Thank you. Today the difference was quite huge: 17C on the map and 25C inside the activity
@gogapo yeah, don’t compare it
@gogapo Wait until winter, then you’ll see how big a difference it will make.
@Mouse-Cruiser ahahaahahahah
