    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Multiple sensor pairing doesn't work as expected
    Scheduled Pinned Locked Moved Watches
    10 Posts 7 Posters 1.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sky-runnerS Offline
      sky-runner Platinum Member
      Switching from one HR sensor to another glitches every single time
      Let’s say I go for a run and I bring another sensor - not the same I used on a previous run. Why? Because I rotate between Suunto HR chest sensor for shorter runs and Coros armband HR sensor for long runs.
      So, first of all, the watch doesn’t automatically try to connect to another HR sensor and instead just uses the built-in optical HR sensor. Not the expected outcome, but OK - let’s go to Exercise Options --> Sensor Data menu and manually connect to the new sensor. That works and the new sensor successfully connects. However when I exit the Exercise Options menu, the watch still doesn’t use the external sensor and remains locked to the built-in sensor! Switching activity type and back or doing any other changes in activity options didn’t help either.
      The only workaround that sometimes works is to exit the activity start screen and go back to watchface, and try to restart the activity again. This seems like a clear software bug to me. Please report it!
      Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
      Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
      Zdeněk HruškaZ jjpazJ isaziI 3 Replies Last reply Reply Quote 4
      • Zdeněk HruškaZ Offline
        Zdeněk Hruška Bronze Member @sky-runner
        @sky-runner Hi, what works for me is to disable the OHR in the menu. Yes, it’s still a workaround but the ohr doesn’t work for me anyway. I am not sure if this is the wanted behavior that the OHR has always the priority. I guess that if you use external sensors than you can use this solution.
        • jjpazJ Online
          jjpaz Bronze Member @sky-runner
          @sky-runner Same behavior here
          Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
          B 1 Reply Last reply Reply Quote 0
          • B Offline
            borgelkranz Bronze Member @jjpaz
            @jjpaz can confirm.
            • isaziI Offline
              isazi Moderator @sky-runner
              @sky-runner no need to report, this should already be fixed in next version
              Blog: isazi's home
              B Dušan KovićD D 3 Replies Last reply Reply Quote 0
              • B Offline
                borgelkranz Bronze Member @isazi
                @isazi good to know 😊👍
                • Dušan KovićD Away
                  Dušan Ković @isazi
                  @isazi any news of next version ETA?
                  SR2
                  SA latest beta
                  Polar Verity Sense
                  Polar H10
                  Vivo x300 Pro
                  • D Offline
                    dombo Bronze Member @isazi
                    @isazi ghost sensors (without name, just two dashes “–” without details) will also be removed by firmware upgrade? I would like to prevent hard reset…
                    isaziI B 2 Replies Last reply Reply Quote 0
                    • isaziI Offline
                      isazi Moderator @dombo
                      @dombo no idea, I have one on my watch, will not hard reset for that (it does not do anything weird), and just wait next update
                      Blog: isazi's home
                      • B Offline
                        borgelkranz Bronze Member @dombo
                        @dombo I got rid of my ghost sensor via a hard reset. The problem that my power meter is detected as a speed sensor that does not transmit data remained. So I decided to downgrade to the prior version because support advised me to do so.
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
