[ bug ] Low brightness setting
Hi,
While display brightness is set to Low, from time to time when I raise my wrist display becomes super bright, then it return to it’s normal level. That was not the case with the race.
It happens either in ‘watch’ mode, without activity, or at the end of an activity when displaying recap and returning to watch mode.
Maybe it also happens during activity, but since it’s often outdoor in daylight I might miss that.
Note: brightness is set to low in general setting and in exercice settings.
@Matteiva Same Here
@Matteiva I have the same behaviour. I wish that Suunto would offer one more setting of the display. A Lower alternative than low, like when you put your watch in Dnd. Before it turned black the light setting dims a little bit more and would be perfect during evenings and the period we are heading to her in Sweden. I find the low setting to be to bright.
Indoor, watch mode, just raising my wrist I and pressing button for full activation of the watch, I was surprise one more time by the brightness. That was not ‘low’ at all, more high than low or even medium. So I went in the general setting, set display to medium and screen came back to an effective ‘medium’ brightness. Then I set it on Low, and then brightness was lower than medium.
So I guess there is a bug about that display setting
Register Login
