    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2max in 9 Peak Pro
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    11 Posts 4 Posters 1.8k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      gdimos
      Hi,
      I’ve recently noticed a VO2max widget appeared in my iPhone, regarding my 9 Peak Pro.
      Unfortunately this has no data. That means it is not getting any data from 9 Peak Pro. I’ve tried through walking and running modes in my watch and still I’m not getting any VO2max results.I think this is not working with 9 Peak Pro…
      So, dear engineers in Suunto, could you pls. check this?
      Thnx
      T M 2 Replies Last reply Reply Quote 0
      • T Offline
        The_77 Silver Members @gdimos
        @gdimos as a 9PP user, I get VO2 max for every run, so must be something in your use case particularly?
        Suunto Spartan Trainer Wrist HR / 9PP Refurb
        M 1 Reply Last reply Reply Quote 2
        • M Offline
          Matúš Bronze Member @The_77
          @The_77 said in VO2max in 9 Peak Pro:
          Same here!
          Suunto 9 Peak Pro Titanium Slate
          Suunto Spartan Sport
          #swatt
          safariS 1 Reply Last reply Reply Quote 1
          • safariS Offline
            safari @Matúš
            @Matúš My long-term vertical does not work anymore.
            history:
            Suunto Vertical 2 titanium Black (new:) )
            suunto vertical solar titanium
            suunto 9 baro
            suunto ambit 3
            suunto ambit 2
            Suunto Smart Heart Rate Belt
            suunto App: apple iphone 14
            M 1 Reply Last reply Reply Quote 0
            • M Offline
              Matúš Bronze Member @safari
              @safari, what do you mean?
              #swatt
              safariS 1 Reply Last reply Reply Quote 0
              • M Offline
                Matúš Bronze Member @gdimos
                @gdimos said in VO2max in 9 Peak Pro:
                Have you set the HR data, as well as the HR zones? Have you pushed enough during your runs, i.e., Z4-Z5?
                #swatt
                • safariS Offline
                  safari @Matúš
                  @Matúš The app says the last VO2max measurement was taken on May 12, 2024. Even though I did the same workouts and used the HR belt, no values ​​for the period after that are listed in the tables.
                  history:
                  suunto 9 baro
                  suunto ambit 3
                  suunto ambit 2
                  • G Offline
                    gdimos
                    Pls. believe me, my Suunto 9 Peak Pro widget shows no data since 27 July 2025… and I never had VO2max data before. But during this time period (27 July until now) I had a lot of walking and running activities using GPS, like 8 hours wakling, 11:17 hours walking, 20 min running with heart rates even at 180bps. So, I don’t bite that something is not correctly adjusted by myself. Or, if this is so, why I don’t get any such instruction for having this properly working? I’ve also asked ChatGPT for finding a solution. In my previous “Garmin life”, everything was working so smooth without any intervention by me so having smartwatch properly working.
                    Guys, I’ve switched to Suunto for battery longevity and I’m facing a lot of issues, bugs etc. Pls. don’t make me go back to Garmin…
                    Thnx
                    T 1 Reply Last reply Reply Quote 0
                    • T Offline
                      @gdimos from memory (this may have changed) you needed at least three runs, which had at least 20 mins minimum of good quality HR data each in order to generate a VO2 Max. Not possible by walking/hiking alone. It may be a daft question, but have you had three of those?
                      G 1 Reply Last reply Reply Quote 0
                      • G Offline
                        gdimos @The_77
                        @The_77 Thank you!
                        No, I hadn’t three runs at least 20 mins minimum and I’m pretty very much sure that this is not the case. There is not mentioned anywhere such a minimum of three runs at least 20 mins neither in Suunto or to any other competitive such product. Most likely, it’s another s/w bug of Suunto.
                        Anyway, I would like to thank all of the members in this forum for responding to my questions during the last 12 months - it was really a nice experience.
                        But I’ve been tired questioning/challenging Suunto for the obvious (basic s/w quality assurance), so I’m going out from the forum and I’m looking for my next smartwatch.
                        Thank you All
                        Cheers
                        • T Offline
                          @gdimos it has changed to at least 15 minutes (I would assume of good quality data). If it doesn’t show in the watch widget called progress that information I would be surprised?
                          https://www.suunto.com/en-gb/Support/Product-support/suunto_9_peak_pro/suunto_9_peak_pro/widgets/progress/
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
