    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    AMOLED displays, AOD OFF and trail running
    Scheduled Pinned Locked Moved Watches
    10 Posts 6 Posters 1.3k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      Luis Andés Olmedo Bronze Member
      Hello all, I’d like to open a discussion on this topic…
      AMOLED displays have an obvious advantage over MIP: visibility, more or less we all agree on that (Race and Race 2 displays are awsome in cloudy conditions).
      But AMOLED displays and AOD ON mean a very high battery consumption so many users tend to use AOD OFF which is a good solution. I’ve tried Race and Epix Pro (now I am back to my made_in_Finland Vertical :p) and with none of them I felt really comfortable when running at the mountains in technical areas, when biking or just when being at home and wanted to check the time without moving my arm.
      Most “dangerous” use case is trail running. You are descending or just going over a rocky path and need to check the route… with a MIP watch might not even need to raise your hand. With and AMOLED: raise your hand and wait for the display to wake-up…
      I never got used to that.
      More or less same when biking and following a track.
      How do you manage those situations with an AMOLED watch?
      isaziI Dušan KovićD Brad_OlwinB 3 Replies Last reply Reply Quote 4
      • isaziI Offline
        isazi Moderator @Luis Andés Olmedo
        @Luis-Andés-Olmedo for mountain or fast activities, I keep AOD on. My activities last at most 10-12 hours, so no problem for me to do that.
        Blog: isazi's home
        • Dušan KovićD Offline
          Dušan Ković @Luis Andés Olmedo
          @Luis-Andés-Olmedo I Keep AOD on medium brightness and raise to wake off. It is good enough for trail runs and gravel biking. For slow paced activities - hiking, mountaineering, climbing, ski touring, etc - AOD off, raise to wake on, medium brightness. Battery lasts forever nevertheless.
          SR
          SA latest beta
          Polar Verity Sense
          Polar H10
          Pixel 6
          • VoiGASV Offline
            VoiGAS Gold Members
            For me AOD on and Lift to wake off (its too slow). I have it on full brightness and then it is usable most of the time.
            The problem is the light sensor logic. When you have direct light rays on you Watch-Side arm (like sun on the left) it raises the brightness level to be readable really good. If you run back the same way and have the sun on the right side it is dimmed down until its hardly readable.
            With some tweaks on this logic AMOLED could be really usable, currently for me it is on the edge…
            Hoping for a Vertical2 with MIPS, but maybe the Race2 is already better - they implemented a new display
            Race S
            Vertical
            Ambit3 Vertical
            L 1 Reply Last reply Reply Quote 2
            • L Offline
              Luis Andés Olmedo Bronze Member @VoiGAS
              @VoiGAS said in AMOLED displays, AOD OFF and trail running:
              More or less same logic with light sensor on SV. When running in a forest with sun/shadows if the watch on the “sunny side” but your head is not, the light does not turn on when you look at the watch. Not a real issue with a MIP display but sometimes annoying if the sun/shadow difference is big (and in some forests it is)
              VoiGASV 1 Reply Last reply Reply Quote 1
              • VoiGASV Offline
                VoiGAS Gold Members @Luis Andés Olmedo
                @Luis-Andés-Olmedo Secret trick: At least on the Race S you can touch the crown to activate the display. Even works with the back of your hand if you have the watch below your wrist. Works way faster then lift to wake - I would say instantly
                Race S
                Vertical
                Ambit3 Vertical
                Dušan KovićD 1 Reply Last reply Reply Quote 2
                  Dušan Ković @VoiGAS
                  @VoiGAS Same on Race, just touching the crown wakes display
                  SR
                  SA latest beta
                  Polar Verity Sense
                  Polar H10
                  Pixel 6
                  • Tomas5T Offline
                    Tomas5 Gold Members
                    May i extend this topic a little bit? How does AOD behave on Race, Race S, Race 2. Does it have some autobrightnes? For example when i am outside i need high brightnes because of sun but when i wake up in middle of night i don’t need to flash my eyes with extensive bright display. Does AOD adjust to outside conditions?
                    And does suunto list battery life with AOD 24/7 enabled?
                    Suunto Ambit 2, Suunto 5, Suunto Race 2
                    • Brad_OlwinB Online
                      Brad_Olwin Moderator @Luis Andés Olmedo
                      @Luis-Andés-Olmedo I never use AOD. Raise to wake is plenty fast and I don’t need to look at my watch that often. Certainly not when I am trying to move fast on technical terrain.
                      Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                      • VoiGASV Offline
                        VoiGAS Gold Members @Tomas5
                        @Tomas5 A little late, but yes - at least my Race S has automatic brightness. It works sometimes good, sometimes really bad.
                        Must of the summer with the bright sun coming from one side you either have a really bright and readable display (sun side) or its unreadable (shadow side).
                        Yesterday on a sunny autumn trailrun in the woods it worked really great. I think the more dizzy light helps.
                        My conclusion is: AMOLED can work great - when the software helps to optimize the light settings. There is room for improvement and so is hope…
                        Race S
                        Vertical
                        Ambit3 Vertical
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
