    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical Solar add sport Caving speleology?
    Scheduled Pinned Locked Moved Suunto Vertical
    8 Posts 3 Posters 859 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      emmavet87
      I was wondering why the Suunto Vertical doesn’t include speleology and caving as sports. Is it possible they don’t think of implementing this sport with a widget that always shows the compass and depth, as well as the track taken? It would be helpful if when you discover new routes, you can avoid making mistakes when you turn back. I hope they include this crazy sport, but not in 2025…
      If any Suunto developer reads this, I hope they will soon implement this discipline which is now as much a part of mountaineering as climbing.
      Next update 🤞🏻 i Hope come on Suunto 🔥🔥🔥
      Ze StuartZ EgikaE 2 Replies Last reply Reply Quote 0
      • Ze StuartZ Offline
        Ze Stuart Gold Members @emmavet87
        @emmavet87 you could do compass and depth - assuming the altimeter’s altitude is correct underground - but the track taken would be hard. Are you thinking of something like the dive plots on the Ocean for the track?
        I think caving is even more niche than OWS, but no argument it would be cool!
        https://zulusierra.co
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          emmavet87 @Ze Stuart
          @Ze-Stuart sì forse è vero. Sarà difficile far prendere la traccia gps a -200 o -600. Ma un sistema di orientamento con bussola e profondimetro è fattibile. certo che se trovassero il sistema di fare anche solo una traccia del percorso tramite il profondimetro e la bussola mi basterebbe la traccia tipo quella dei vecchi Suunto da punto 1 scendi e arrivato a punto 2 risali ma credo sia fattibile solo col GPS. Io ho lanciato la sfida a Suunto spero la implementino considerando che il speleologia come attività oltre che a livello sportivo è anche per la comunità scientifica ne gioverebbero tutti. Suunto dai inserisci lo sport Speleologia per favore .
          Ze StuartZ 1 Reply Last reply Reply Quote 0
          • EgikaE Offline
            Egika Platinum Member @emmavet87
            @emmavet87 I suggest you build your own climbing or so sport mode that shows depths and other data you need.
            There is current altitude or altitude difference to start, compass heading etc. available as a data fields.
            t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
              @emmavet87 difficile --> impossible as GNSS (GPS) doesn’t work underground. The Ocean uses magic (undocumented sensor fusion) to build a 3D track of the route that’s visible after the dive in the app, but not during.
              And exactly what @Egika said.
              • E Offline
                @Ze-Stuart said in Suunto Vertical Solar add sport Caving speleology?:
                If the vertical and ocean have the same sensors, I think they could do a simple update and use the same algorithms for calculating caving depths. Suunto, please read these threads and create something for caving. thank you so much for the information you are giving me.
                • EgikaE Offline
                  @emmavet87 caving depths measurement should work from atmospheric pressure.
                  At least, when the whole cave is not pressurized.
                  Just give it a try. I think it should work well.
                  • E Offline
                    emmavet87 @Egika
                    @Egika ok Yesterday I started the barometer with the climbing function and the Climb widget. It works, but it would be nice if they only did the activity with the barometer function! It works, though! Go app-caving!
                    ![alt text][url=https://postimg.cc/Mv5js2LX][img]https://i.postimg.cc/Mv5js2LX/IMG-20250928-182106846.jpg[/img][/url](image url)
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
