    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after soft-reset / restart
    Scheduled Pinned Locked Moved Suunto Vertical
    6 Posts 3 Posters 868 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Panagiotis KritikakosP Offline
      Panagiotis Kritikakos Gold Members
      I’ve been mentioning the behaviour on a different post but might be better to create a new topic.
      After some map issues and a suggestion to soft-reset the watch I came accross extensive battery drain. On the first case, right after rebooting, the watched consumed 40+% in 1.5hour (no recording activity or anything else). It went from 61%->20% in 1.5 hour so and it stabilized there. I’ve let/caused (torch on) the battery to drop down to 4% and then made a full charge in case it was a battery calibration issue. It seemed fine afterwards.
      Yesterday, after getting the update the watch made a restart. Same behaviour appeared. It went from 93% to 45% in an hour or so and after 6-7 hours it went down to 6%. I then charged it and since then it seems fine. Normal battery usage both when recording activity and not.
      After the last reboot, I noticed that the watch was warmer than normal. Like something was going on inside. Any ideas?
      Suunto Vertical Titanium Solar | 9 Peak | Ambit 3 Peak | 3 | Gekko
      Garmin eTrex 30x
      HighlandsH 1 Reply Last reply Reply Quote 0
      • HighlandsH Offline
        Highlands @Panagiotis Kritikakos
        @Panagiotis-Kritikakos Sorry, about your problems. Did you try factory settings? If this doesn’t help, I’d contact the support.
        Panagiotis KritikakosP 1 Reply Last reply Reply Quote 0
          Panagiotis Kritikakos Gold Members @Highlands
          @Highlands I had tried a factory reset but it re-occured. After a full charge everything seems fine until the next soft-reset.
          Garmin eTrex 30x
          thanasisT 1 Reply Last reply Reply Quote 0
          • thanasisT Offline
            thanasis Bronze Member @Panagiotis Kritikakos
            @Panagiotis-Kritikakos I m afraid you may need to send it to the service Center
              Panagiotis Kritikakos Gold Members @thanasis
              @thanasis I am afraid so too. Will have to wait some time and will give it some more chances, perhaps with another factory reset.
              Garmin eTrex 30x
                I applied the last update. The watch restarted and the same issue occured. This time, I tried to change to power saving mode.I let it there for ~10 minutes, no battery drop at all. I enabled normal mode again and the consumption seems to be back to normal again. At least there seems to be a workaround.
                Garmin eTrex 30x
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
