Multiple tank pods
It looks like the ocean supports multiple tank pods, but only in the mixed gas situation. Does anyone know how it (or even if it) would work if you have 2 cylinders of the same gas, ie sidemount setup?
@kevd62 But isn’t that the same situation like mixed gas? You have to switch from one gas tank to the other, even if both are the same mix.
Register Login
