    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Error recording activity over 15 days
    Scheduled Pinned Locked Moved Suunto Ocean
    10 Posts 4 Posters 610 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      Angusmil
      Hello,
      I’m writing to report an issue I’m experiencing with the synchronization of an activity. It’s a special activity, but I would like to know whether this is normal or not. Here’s the problem:
      I’ve been sailing for 15 consecutive days and completed a transatlantic crossing by sailboat. During those 15 days, I was recording the route, both to have the track and to keep records of speeds and averages.
      The issue appeared when I arrived and stopped the recording. The activity doesn’t upload to the phone, and when I go to the activity logbook on the watch, it crashes and restarts. Now that I have this error, I can’t sync anything, and I can’t connect the watch to the phone.
      I’m attaching photos:
      https://u.pcloud.link/publink/show?code=XZ7TzS5ZQBYalW5aCHJAJhJ3XniGEzSTWwhX
      https://u.pcloud.link/publink/show?code=XZVTzS5Z6XDymGV89LRtHHxn8fBC5RSSy4lV
      In the first photo, five seconds after seeing this, the data disappears and the watch crashes.
      In the second photo, when I click on Retry, nothing happens; as a result, I can’t configure the watch.
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Angusmil
        @Angusmil Congratulations! What phone and OS are you using? What settings did you use on the watch to record? Tour mode? Don’t reset the watch, hopefully someone can help here.
        @pavel.samokha Anything that can be done about this?
        Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing
        • A Offline
          Angusmil
          Hi,
          Thanks for the response. Today, after three days, the data finally uploaded to the phone and synchronized. I can now access the watch settings again on my phone, and it’s no longer stuck trying to sync unsuccessfully. However, some issues still persist: when I go to the activity from the phone, I can’t see the track with video, clicking play results in an error. Also, when I try to access the activity data from the logbook on the watch, it crashes and restarts.
          I’m using a Xiaomi Android device. The activity is “sail,” and I had set the GPS to maximum quality for a few days and then switched to Ultra mode, I believe.
          In any case, I’m glad I can now use the watch with my phone properly. Fortunately, the Suunto Ocean watch can cross oceans! It would be great to be able to see the track video.
          Thanks.
          Stefano M64S 1 Reply Last reply Reply Quote 4
          • Stefano M64S Offline
            Stefano M64 Silver Members @Angusmil
            @Angusmil said in Error recording activity over 15 days:
            I guess that the data you recorded could be too large to be properly handled, likely at Suunto they didn’t take into account the possibility to record an activity lasting that long(!). Don’t know if changing the GPS accuracy could be part of the problem.
            For your next adventure maybe better to split the crossing into shorter activities, you could merge the related GPX files in a second moment.
            Suunto Vector . Vector HR . Core . Race & Race S
            • A Offline
              Angusmil
              Hi,
              Yes, I guess it’s not designed for that, but I just wanted to report this issue and maybe even if it’s not intended for that use, it should still work, I don’t know how it’s programmed. It would also be nice to have an activity type called “offshore sail” or something similar, allowing the full recording of a sailing trip.
              Regarding merging GPX files, can it be done from the Suunto app?
              Thanks.
              Stefano M64S 1 Reply Last reply Reply Quote 0
                Brad_Olwin Moderator @Stefano M64
                @Stefano-M64 @Angusmil Suunto does take into account long activities. This might be one of the longer ones. Recording on Ultra or Tour reduces the data density and helps with the longer events. When syncing a lot of data a high quality WiFi connection is often needed. Poor cellular connections don’t permit the data to sync.
                  not to my knowledge, but there are many third party tools that can edit, merge, split gpx files, for example https://gpx.studio
                  • A Offline
                    Angusmil
                    Hi, thanks for replying. Next time I’ll set the GPS to Ultra from the start. I think I changed it halfway through the journey.
                    What I find strange is that I can’t view the data on the watch — when I click on the logbook, it freezes. Maybe they still need to fine-tune those details.
                    Thanks for the info on modifying the GPX.
                    In any case, if there’s no solution for now, the best option will be to record it in different stages.
                    Thanks!
                    F 1 Reply Last reply Reply Quote 0
                    • F Offline
                      far-blue Bronze Member @Angusmil
                      @Angusmil Congrats on the sailing achievement 🙂 I recommend Suunto sponsor you on more trips as a beta tester 😄
                      • A Offline
                        Angusmil
                        I’d love to, where do I sign? Hahaha
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
