    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    (Resolved) Sync issue after 2.40.44 – Suunto Vertical + iOS - (Server Issue)
    Scheduled Pinned Locked Moved Suunto Vertical
    10 Posts 5 Posters 1.2k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      bruno.tanqueray
      Sorry I sent my post in Race and not Vertical… Can’t delete it in Race
      Hi everyone,
      Since updating to firmware 2.40.44 on my Suunto Vertical two days ago, I’m having today intermittent sync issues with the Suunto App on iOS:
      Some activities are transferred, but they often fail to load fully:
      → I cannot edit tags or access ZoneSense analysis, even though the activity appears in the app.
      It seems worse when syncing multiple activities:
      → For example, today I recorded two activities; both appeared in the app but were partially processed.
      Yesterday, with only one activity, everything worked correctly.
      What I’ve already done:
      Removed the watch from iOS Bluetooth
      Deleted and reinstalled Suunto App
      Rebooted the iPhone and re-paired the watch
      → Issue persists.
      This never happened with firmware 2.40.38.
      Is anyone experiencing the same?
      Suunto team: would a rollback be possible, or is a fix planned soon?
      Thanks,
      Bruno
      D F Brad_OlwinB 4 Replies Last reply Reply Quote 2
      • D Offline
        dombo Bronze Member @bruno.tanqueray
        @bruno.tanqueray I have the same issue. my vertical is not updated yet. sync to the app is OK, but uploadint to the cloud is still in progress. so I assume it is cloud issue, not fw issue
        B 1 Reply Last reply Reply Quote 0
        • B Offline
          bruno.tanqueray
          Hi everyone,
          After facing sync issues with firmware 2.40.44 on my Suunto Vertical (iOS), I used the hidden OTA method to rollback to firmware 2.40.38 via the developer menu (Settings > General > About > hold lower button).
          The downgrade worked fine, and I also activated the option to keep the version for 30 days.
          However, the problem remains:
          Activities are syncing incompletely
          I can’t edit tags or access ZoneSense data
          The issue seems worse when syncing multiple activities
          Even with 2.40.38, the app behaves exactly the same
          I’ve done a full reset procedure:
          Bluetooth reset, Suunto App reinstall, reboot, re-pairing — nothing helped.
          At this point, I strongly suspect the issue comes from the Suunto App itself (iOS) or possibly corrupted activity files on the watch.
          Would appreciate any insights or support from Suunto staff.
          Thanks in advance,
          Bruno
          • B Offline
            bruno.tanqueray @dombo
            @dombo : Thank you
            So I will roll back to 2.40.44
            D GiPFELKiNDG 2 Replies Last reply Reply Quote 0
            • D Offline
              @bruno.tanqueray my newer test activity was uploaded fine. It might be some issue on the suunto servers in time of uploading activity. I synced my activity around 14:30 CEST
              • GiPFELKiNDG Online
                GiPFELKiND Silver Members @bruno.tanqueray
                @bruno.tanqueray and like everytime after new Update simple do a downgrade 😂
                If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                • F Offline
                  Freezer Bronze Member @bruno.tanqueray
                  @bruno.tanqueray @pavel.samokha I have the same problem after upgrading Vertical to 2.40.44 - iOS Suunto App stuck at “Uploading Activity” since this afternoon (5+ hours).
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @bruno.tanqueray
                    @bruno.tanqueray This is a server issue NOT a watch or firmware issue. I reported the problem. Affecting me as well.
                    Vector/T6c/Vertical 2 Ti
                    B 1 Reply Last reply Reply Quote 1
                    • B Offline
                      bruno.tanqueray @Brad_Olwin
                      @Brad_Olwin Thank you Brad.
                      It’s working again.
                      Now I need to re-Update my Vertical.
                      It’s a shame we didn’t receive any alert from SUUNTO.
                      Regards
                      • F Offline
                        Deleted - unfortunate double post
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
