    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Two Questions about HR Strap
    Scheduled Pinned Locked Moved Accessories and other products
    24 Posts 12 Posters 4.5k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tami999T Online
      Tami999 Silver Members
      Hello. I was thinking about buying Chest strap to pair with my SV. I got two questsions.
      1. If i pair stap with my watch I want to measure my HR out of activity from watch, and from strap when doing activity. Do I need to set it every time, or that how its works? Every time I start running/cycling I need to set which device if should use to measure? Or I do it only one time, and after cycling for example, and finish activity, it automatically switch to my watch HR, than again next day I go cycling, it will automatically switch to chest strap when I start activity?
      2. Which one do You recommend? I was thinking about SUUNTO SMART HEART RATE BELT and Polar H10 chest strap. Price is basically the same. Or maybe You know any better?
      Thanks!
      L Ars VitaeA 2 Replies Last reply Reply Quote 0
      • L Offline
        larrybbaker @Tami999
        @Tami999 once the HRM is paired to the watch it will pick up for each activity - as long as you are using the same HRM. You can only pair one. As far as device recommendations - as long as it is Bluetooth and if you want to sue ZoneSense it has to measure R-R intervals.
        Vertical Ti Solar
        Vertical 2
        Race 2
        iPhone 17 Pro
        • 2 Online
          2b2bff Gold Members
          The only advantage the Suunto belt has is its memory. So you can use it while swimming…
          Suunto Race S
          Garmin Epix Pro
          • Tami999T Online
            Thanks, I searched some more info and ordered Suunto :). Seems like it also got a bit bigger battery than Polar.
            • Ars VitaeA Offline
              Ars Vitae Silver Members @Tami999
              @Tami999 I don’t have any comparison with other’s brand but I’m using Suunto chest belt and so far no problems. Instant connectivity, direct HR reading, comfortable belt that doesn’t slip on the body (at least in my case).
              • Sergei LadeishchikovS Offline
                Sergei Ladeishchikov Bronze Member
                Hello everyone! Based on your experience, can you tell me if it is acceptable to leave the Suunto heart rate sensor connected to the belt when not in use? Will the battery run out? As far as I remember, I left the Polar H10 sensor connected to the belt, the battery ran out quickly. The Suunto sensor is very difficult to disconnect from the belt and I am afraid to damage the contacts by constantly connecting/disconnecting.
                Mouse CruiserM 1 Reply Last reply Reply Quote 0
                • Mouse CruiserM Offline
                  Mouse Cruiser Bronze Member @Sergei Ladeishchikov
                  @Sergei-Ladeishchikov In my case, it’s pretty simple: when I go to train, I put on the HR strap, when I’m done, I put it away, wash it, and forget about it. IMHO If it’s idle, it goes to sleep, so there’s no need to turn the device on or off every time.
                  Suunto Vertical
                  Suunto 9 Baro
                  Suunto Spartan
                  Suunto Ambit3 peak
                  • Stefano M64S Online
                    Stefano M64 Silver Members
                    form an electrical point of view, it seems to me that the belt just acts as an extension of the contact pins of the sensor, that is the pads you have to wet, if the belt isn’t in use the sensor shouldn’t drain more current
                    Suunto Vector . Vector HR . Core . Race & Race S
                      theoretically yes, but the discharge was present for several days in my previous H10, I had to attach and detach the sensor to the belt every training. I checked the detection of the Suunto belt when not in use, through the watch and SA, the belt was not found))
                      Stefano M64S Brad_OlwinB 2 Replies Last reply Reply Quote 0
                        Stefano M64 Silver Members @Sergei Ladeishchikov
                        @Sergei-Ladeishchikov said in Two Questions about HR Strap:
                        it is only detected when the skin closes the electrical circuit
                        • Tami999T Online
                          So far Iam happy. HR seems very stable now, without huge drops. With same activity I had 140-150. Before 130-150 with drops to 60 or 40. I thought Iam dying 😄
                          . Does anyone know if its good to use CR2032 battery instead of 2050? I got a few brand new.
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @Sergei Ladeishchikov
                            @Sergei-Ladeishchikov You do not need to disconnect the sensor. I never do.
                            Vector/T6c/Vertical 2 Ti
                            Sergei LadeishchikovS 1 Reply Last reply Reply Quote 0
                              Sergei Ladeishchikov Bronze Member @Brad_Olwin
                              @Brad_Olwin I thought so) but I have problems with the heart rate, sometimes there is no data from the belt for 20 seconds or 1 minute. My belt is new, about 1 or 2 weeks. Almost every long workout I notice the lack of data, usually I am already warmed up enough and the belt is wet. SA showed the pulse at this moment as a straight line, but in Humango and Intervals zero readings are visible. Before the Suunto belt I used Polar H10, I had this problem with it, but the belt was quite old and the pulse sometimes just hung, but did not disappear. Does anyone have such behavior of the belt or is my belt or sensor faulty?
                              I use SV.
                                @Sergei-Ladeishchikov Maybe the battery is old, the belt should show HR immediately if wet. Mine does. I assume you have replaced the battery. What color is the material between the contacts on the belt, it should be grey not black. This is on the front side between the contacts that the sensor attaches to.
                                  @Brad_Olwin The battery is new, shows 100%. The contact pad is gray. The data is interrupted not at the beginning, but during the activity. Since this happened with the old H10, and now with the new Suunto, could the problem be in something else? For example, in the connection between the sensor and the watch?
                                  A recent example is below, 45-46 minutes.
                                  Today’s activity also had a couple of gaps 2 hours after the start of the activity.
                                    This could be due to the strap getting dry and/or a tech shirt that may cause static. The first graph is HR, correct? I see where data are missing. I have had the same occur to me when on a SkiMo outing caused by either the belt not completely contacting the skin and dry, cold weather where the belt is not wet and I am not sweating enough. You might try a gel on the belt, it looks to me like the connection between you and the belt is an issue.
                                      @Brad_Olwin Yes, the first heart rate graph. Yes, I will try using the gel. Thank you!
                                      • M Offline
                                        Mattg576 @Tami999
                                        @Tami999 I’ve used CR2032 batteries in my Suunto HR belt for years without any problems👍
                                        Race
                                        9 Peak
                                        Ambit 3 Peak
                                        Ambit 2R (sold)
                                        Suunto T3d (expired)
                                        VoiGASV Mff73M 2 Replies Last reply Reply Quote 2
                                        • VoiGASV Offline
                                          VoiGAS Gold Members @Mattg576
                                          @Mattg576 Nice Hack! So the battery should have more capacity? Less effort to change and less trash 😀
                                          Race S
                                          Vertical Titanium Solar
                                          Ambit3 Vertical
                                          Eon Core
                                          • Mff73M Online
                                            Mff73 @Mattg576
                                            @Mattg576 said in Two Questions about HR Strap:
                                            And still waterproof? 2032 are little thicker no?
                                            SSU (retired), SV1, SV2
                                            Wife : S9PP
                                            SA: Always the latest beta :)
                                            Android + Galaxy S205G
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
