    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    to solar or not to solar?
    Scheduled Pinned Locked Moved Suunto Vertical
    28 Posts 19 Posters 5.4k Views 19 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • VoiGASV Offline
      VoiGAS Gold Members
      The Vertical Solar is an absolutely absurde watch. I don’t remember when I last charged it because it lasts like forever. Weeks, Months, or if you don’t use it as a Smartwatch and give it proper sun really forever.
      Today in the morning it had 83%.
      Put it in the sun (behind a window) for 2-3 hours: 84%.
      Running 1,5 hours 82%
      Placing it outside in the sun for 2 hours: 83% again! And still charging…
      Complete massive overkill. But I like it 😁
      Race S
      Vertical Titanium Solar
      Ambit3 Vertical
      Eon Core
      ElectronBadgerE thanasisT 2 Replies Last reply Reply Quote 4
      • ElectronBadgerE Offline
        ElectronBadger @VoiGAS
        I also enjoy mine A LOT. All types of my activities, bike rides, daily trainings, ultra races, adventure trekkings, yoga, you name it. Really excellent battery life. The best watch I’ve ever had.
        Suunto Vertical Solar All Black
        1 Reply Last reply Reply Quote 3
        • thanasisT Offline
          thanasis Bronze Member @VoiGAS
          @VoiGAS can you share the setup of this ? Do you use oHR? Notifications? Strap ?
          Thanks
          VoiGASV 1 Reply Last reply Reply Quote 0
          • VoiGASV Offline
            VoiGAS Gold Members @thanasis
            @thanasis None of that. Just syncing with the App from time to time. It would not work if you wear it between the activities. I just used it for running and then leave it in the sun.
            Today was a pause day, so the watch got a full day in the sun without interruptions. Went up from 80% to 84% 😀
            Race S
            Ambit3 Vertical
            Eon Core
            sartoricS 1 Reply Last reply Reply Quote 0
            • sartoricS Offline
              sartoric Moderator @VoiGAS
              @VoiGAS
              Be aware that it’s not recommended
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.8 beta
              • VoiGASV Offline
                VoiGAS Gold Members @sartoric
                @sartoric Didn’t know that, thank you for the warning! Its still cold here, so I hope the watch didn’t got hurt
                Race S
                Ambit3 Vertical
                Eon Core
                SquirrelS 1 Reply Last reply Reply Quote 0
                • SquirrelS Offline
                  Squirrel Silver Members @VoiGAS
                  @VoiGAS It all depends on the internal and thus battery temperature. You can easily check the internal temperature by looking at Alti/Baro/Temp widget after some time in direct sunlight. It depends on the ambient air temperature and also largely on the amount of infrared radiation the watch is exposed to. For example if the watch is in the interior and behind IR blocking glass window, the internal temperature would be very close to ambient temperature considering the very low charging power generated by photovoltaic panel. If this is let’s say between 20-25°C ambient air, that’s way more favorable for long term battery health than on the wrist temperature of ~32°C (currently on my wrist).
                  Leaving it directly outside is of course a bad idea for prolonged periods, unless you can compensate by low ambient air temperature that keeps internal temperature from raising to unhealthy levels.
                  Race S
                  VoiGASV 1 Reply Last reply Reply Quote 2
                  • VoiGASV Offline
                    VoiGAS Gold Members @Squirrel
                    @Squirrel Thank you! So I will charge it inside from now on.
                    Race S
                    Ambit3 Vertical
                    Eon Core
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
