    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Race S altitude issues during activity
    Scheduled Pinned Locked Moved Suunto Race S
    6 Posts 4 Posters 990 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • AnttiMA Offline
      AnttiM
      Hi,
      During activities I have randomly encounter issue where altitude has crazy spikes/drops causing the whole activity to get wrong readings eg. total distance and ascents/descents are way off.
      GPS trail looks ok, it draws the route correctly on the map.
      In an activity where the normal readings should be maybe ~300m or so.
      I have done soft reset, regular sync with app, calibration, auto adjustment of altitude and waited for GPS before activity. I still randomly encounter this.
      Anyone else having same issue? Thanks!
      S Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • S Offline
        spardic @AnttiM
        @AnttiM was it a windy day?
        AnttiMA 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @AnttiM
          @AnttiM Looks as if the baro hole is blocked or your skin is covering the sensor holes that are on the opposite side of the crown. You can check them and make sure that nothing is pushing up against the sensor holes.
          Vector/T6c/Vertical 2 Ti
          • AnttiMA Offline
            AnttiM @Brad_Olwin
            @Brad_Olwin Activities have been MTB on a winter trail so yes skin, clothing etc. can be clogging the holes. Need to adjust the positioning of the watch on my wrist. I’ll keep an eye on this.
            Thanks!
            • AnttiMA Offline
              AnttiM @spardic
              @spardic I cant recall, but at my case i dont think wind has affected since the clock mainly is under jacket.
              Today again 2km added distance and a section where altitude jumps around.
              This happened in a section/trail with quite intense movement so my guess is wrist is blocking the baro sensor holes causing “heavy” pressure changes as @Brad_Olwin stated
              I guess there is no way to disable baro functionality during activity?
              • Nicolò TedeschiN Offline
                Nicolò Tedeschi
                I have similar issue but looking at the graph I see sporadic drops in altitude of about 100m here and there, of course no wind no clothes or anything that might cause external reading problems. Haven’t found a way to solve it, but watch worked correctly the first 3/4 months.
                It’s quite a problem since it’s one of the few information that really interest me. Could it be a hardware problem?
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
