    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Structured workouts manual start
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    8 Posts 4 Posters 1.2k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sorinusS Offline
      sorinus
      Hi,
      I would like to start a Structured Workout guide manually, after some time the exercise is started. I am doing a warmup, then at some point I want to start interval training on the spot. But it looks like if the guide is loaded then it’s starting right when I start the exercise.
      Is it even possible to start the workout manually later through the exercise? (I know I can add a warmup step in the structured workout setup but I’d rather not because I don’t have a pre-planned distance or time for the warmup).
      Thank you!
      Suunto Vertical Ti
      T 1 Reply Last reply Reply Quote 0
      • T Offline
        The_77 Silver Members @sorinus
        @sorinus said in Structured workouts manual start:
        Not that it entirely solves your issue, but you can set the warm up to end on lap button press, with no pre-determined distance, which is an option.
        Else you can open the options menu mid activity, scroll down to S+ apps, find the one you want, check it on and you’re good to go.
        Suunto Spartan Trainer Wrist HR / 9PP Refurb
        sorinusS 1 Reply Last reply Reply Quote 2
        • sorinusS Offline
          sorinus @The_77
          @The_77 said in Structured workouts manual start:
          Not optimum but will work I guess, thank you.
          Suunto Vertical Ti
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @sorinus
            Why don’t you just set the warm up to lap button press? Just as @The_77 suggested! This is an optimum simple solution.
            Vector/T6c/Vertical 2 Ti
            sorinusS 1 Reply Last reply Reply Quote 1
            • sorinusS Offline
              sorinus @Brad_Olwin
              @Brad_Olwin Because I dont know how long warm up will take.
              Suunto Vertical Ti
              TieutieuT 1 Reply Last reply Reply Quote 0
              • TieutieuT Offline
                Tieutieu Platinum Member @sorinus
                @sorinus that’s precisely what « press button » for next step is meant for , as mentioned above.
                You don’t know how long your warm up will take ; so do I most of time.
                Warmup is part of structured workout.
                I press lap button when my warmup is over and then It starts next steps of my session.
                I also often use this between two workouts « blocks » when I’m trail running for instance and that I need to reach a particular area (first block in a slope, 2nd block in another one) but don’t know how long exactly it could take
                Suunto’s devices at home :
                Vertical titanium solar
                Suunto Race S
                S9pp titanium sand
                Suunto Wing & Spark
                S9B titanium Ambassador edition, A3P, X6
                sorinusS 1 Reply Last reply Reply Quote 5
                • sorinusS Offline
                  sorinus @Tieutieu
                  @Tieutieu Many thanks, exactly what I need then (I missunderstood it when I read the manual).
                  Suunto Vertical Ti
                  Brad_OlwinB 1 Reply Last reply Reply Quote 4
                    @sorinus Glad @Tieutieu explained, I did not completely understand your issue, sorry. I do exactly as @Tieutieu stated, makes it easy to start your intervals whenever you want.
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
