    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9PP Elevation changing when sitting still
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    18 Posts 6 Posters 1.5k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      Oxhill_Runner
      I have a S9PP, and I am constantly having to adjust my altitude, even when sitting at my desk.
      I do a mixture of sailing and trail running, so knowing reliable barometer & altitude data is an important safety factor.
      On my old watch (Ambit peak 3), you could select a profile to use with the activity, locking either the barometer or altitude.
      Can Suunto bring this back please?
      M Brad_OlwinB flo7zF 3 Replies Last reply Reply Quote 2
      • M Offline
        maszop Bronze Member @Oxhill_Runner
        @Oxhill_Runner I also liked this option in older watches 👍
        • Brad_OlwinB Online
          Brad_Olwin Moderator @Oxhill_Runner
          @Oxhill_Runner This is handled automatically now so unlikely that a manual feature will return. You may have a clogged sensor or a faulty sensor, I would attempt cleaning. I rarely ever adjust altitude and when I do, I use Auto adjust in the Alti/Baro settings so a strong GPS fix is enabled.
          Vector/T6c/Vertical 2 Ti
          M 1 Reply Last reply Reply Quote 0
          • M Offline
            maszop Bronze Member @Brad_Olwin
            @Brad_Olwin Automatics unfortunately sometimes or often (depending on circumstances) fail. In my case, every few days it deviates significantly, currently: -99m, which is very incorrect and has to be manually corrected every few days.
            I live in a very stormy place with significant pressure changes.
              Brad_Olwin Moderator @maszop
              @maszop I also live in a place with dramatic pressure and weather changes situated between mountains at 4000-4300m within 25km and plains to the east at an altitude of 1600m. We have dramatic and rapid weather changes (with obvious changes in pressure and high winds). I do not expect my altitude to be “perfect” and there is a 200m elevation change between work and home. My watches (includes 9PP, Vertical, Race and Race S) are typically very close (within 25m or so) to the correct altitude. When exercising outdoors FusedAlti works and altitudes are spot on. If way off I perform an auto adjust as described in the manual. I do not manually adjust as my altitude and that of the sensors at airports differ due to location and micro climate differences.
              M 1 Reply Last reply Reply Quote 1
              • M Offline
                @Brad_Olwin It works ok, if there is some activity, then the FusedAlti automation corrects it.
                However, when there is no activity for a few days, another automation (responsible for selecting the barometer/altimeter work) fails.
                These are two different tools.
                • flo7zF Offline
                  flo7z Silver Members @Oxhill_Runner
                  @Oxhill_Runner
                  I am having the same issue.
                  I just sent my watch back to the Suunto repair center.
                  see this other thread
                  https://forum.suunto.com/topic/11809/problema-altimeter/4
                  Florian Z.
                  Suunto 9 Peak Pro
                  Suunto Wings
                  Suunto D4
                  Suunto Ambit 3 Peak
                  O 1 Reply Last reply Reply Quote 0
                  • O Offline
                    Oxhill_Runner @flo7z
                    @flo7z
                    My elevation data looks very similar to your watch, and I haven’t left the house all day. -65m now…
                    I’ll start using Fused Alti more but it takes 10-15 mins, needs to be outside and uses a lot of battery to do so
                    I’ll look for some articles on cleaning the sensor too
                    Mff73M O 2 Replies Last reply Reply Quote 0
                    • Mff73M Offline
                      Mff73 @Oxhill_Runner
                      @Oxhill_Runner
                      Maybe search also for the “fridge test”
                      Baro sensor is correlating absolute
                      pressure and internal temperature to display altitude. A “quick” temperature change must not change the altitude (assuming pressure is not changing during this quick test).
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      • O Offline
                        Oxhill_Runner @Oxhill_Runner
                        @Oxhill_Runner
                        Before Fused Alti
                        After Auto Adjust
                        1 hour after Auto Adjust
                        flo7zF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                        • flo7zF Offline
                          @Oxhill_Runner same behaviour as mine. Contact the support and they will ask you to send it back for repair.
                          How old is your watch ?
                          Florian Z.
                          Suunto 9 Peak Pro
                          Suunto Wings
                          Suunto D4
                          Suunto Ambit 3 Peak
                          O 1 Reply Last reply Reply Quote -1
                            @Oxhill_Runner That is likely a hardware issue.
                            • O Offline
                              @flo7z
                              Thanks everyone for the feedback.
                              I’ll contact Support and see about getting it fixed. I bought the watch in October 2022
                              flo7zF 1 Reply Last reply Reply Quote 0
                              • flo7zF Offline
                                @Oxhill_Runner mine is from Nov. 2022.
                                Florian Z.
                                Suunto 9 Peak Pro
                                Suunto Wings
                                Suunto D4
                                Suunto Ambit 3 Peak
                                • O Offline
                                  @flo7z
                                  Suunto got back and have said to send it in for repair. Its €42 for a Simple Analysis & return freight & then theres the Cost Estimate to repair the watch, plus probably a month without the watch?..
                                  Im thinking of upgrading to the SR. It seems to have the best display (I need readers to see my phone & 9PP) but Im hoping I can read the SR displays 😆
                                  flo7zF VoiGASV 3 Replies Last reply Reply Quote 0
                                  • flo7zF Offline
                                    @Oxhill_Runner yeah I know it costs something and this takes time, I did it because it’s still a great watch, good looking and it’s a pity to throw it away (and it’s not sustainable!).
                                    I still got a good old Ambit that does the job !
                                    Florian Z.
                                    Suunto 9 Peak Pro
                                    Suunto Wings
                                    Suunto D4
                                    Suunto Ambit 3 Peak
                                    • VoiGASV Offline
                                      VoiGAS Gold Members @Oxhill_Runner
                                      @Oxhill_Runner AMOLED is great, but you trade the Always On Display of the 9PP for it. If you can live with the shorter battery life in Smartwatch mode, Raise to wake and don’t plan to mount it on your bike - go for it!
                                      Suunto Race S is smaller, but still bigger than 9PP and cheaper.
                                      But as Flo7z said, the 9PP is still a great watch and one of the last made in finland. If you repair it you can sell it and someone else will be happy with the watch 😀
                                      Race S
                                      Vertical Titanium Solar
                                      Ambit3 Vertical
                                      • flo7zF Offline
                                        @Oxhill_Runner
                                        Suunto sent me a new watch. It took a week in total, incl.shipping.
                                        Florian Z.
                                        Suunto 9 Peak Pro
                                        Suunto Wings
                                        Suunto D4
                                        Suunto Ambit 3 Peak
                                        1 Reply Last reply Reply Quote 5
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
