    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    weather widget not updating
    Scheduled Pinned Locked Moved Suunto Race S
    17 Posts 9 Posters 3.4k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      Antonello85
      Hello,
      on my Race S Titanium the weather widget is not updating consistently.
      It does not synch automatically every hour, sometimes it does not even update when I manually sync the watch with the phone.
      Often the only way to update it is to switch off the Suunto app and re-open it.
      GPS is set-up to be always available for Suunto app.
      App Suunto is set-up to run in the background.
      I have an iPhone.
      Is this a known bug or I should enable something else to make it work?
      Thanks
      F E 2 Replies Last reply Reply Quote 3
      • F Offline
        fmarpe @Antonello85
        @Antonello85 a mí me sucede lo mismo en el Suunto 9 peak pro.
        1 Reply Last reply Reply Quote -1
        • thanasisT Offline
          thanasis Bronze Member
          i have a similar issue with the Vertical. The weather is not updating consistently even if when synching the watch by pressing the synch now button on iOS…
          • Vadim NoginV Offline
            Vadim Nogin
            Same issuse at Race watches + Android
            • AudaxjoeA Offline
              Audaxjoe
              There is a post somewhere about this, it was resolved with changing permissions on the watch. If you search you should be able to find it.
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
              F thanasisT 2 Replies Last reply Reply Quote 0
              • F Offline
                fmarpe @Audaxjoe
                @Audaxjoe Thank you for the answer but I already checked the permissions and they are correctly configured.
                • thanasisT Offline
                  thanasis Bronze Member @Audaxjoe
                  @Audaxjoe said in weather widget not updating:
                  Most probably nothing to do with permissions since 5-6/10 times it works but the rest it doesn’t without any obvious reason. As if the app is not synching it to the watch at times while at others it does
                  i Am on iOS
                  X 1 Reply Last reply Reply Quote 0
                  • A Offline
                    Antonello85
                    Hello, I have only seen permissions on the phone (GPS + app running in background) but not on the watch. Where can I find it? i have a Race s.
                    Thank you
                    • HarrySH Offline
                      HarryS
                      Hello!
                      I have exactly the same problem. I use Suunto Race S and an android phone. Permissions are set correctly.
                      Is there a solution to that problem?
                      Thanks!
                      isaziI 1 Reply Last reply Reply Quote 0
                      • isaziI Online
                        isazi Moderator @HarryS
                        @HarryS is location always active, or only when using the app?
                        Blog: isazi's home
                        HarrySH 1 Reply Last reply Reply Quote 0
                        • E Online
                          elbee @Antonello85
                          @Antonello85
                          I have the same. I have an iPhone, app updates in the background are allowed, always access to gps, I leave the app running. Sometimes it updates the weather, but too often it doesn’t.
                          But if it works, it is so much better than on garmin (switched from garmin back to suunto last month). I get local forecasts, the weather station used is shown and air quality is reported. None of this is on garmins weather app.
                          Suunto t3c | Suunto Ambit 3 sport | Tomtom runner 2 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                          Stryd | Bryton Gardia R300L | Polar H9 | Polar oh1+ | Wahoo bolt v2 | 4iiii precision 3
                          • HarrySH Offline
                            HarryS @isazi
                            @isazi said in weather widget not updating:
                            Yes, location is always active.
                            • HarrySH Offline
                              HarryS
                              Hello,
                              since we got a new firmware update to 2.39.44 the problem is solved. 😊 👍
                              …at least for my watch.
                              Thanks, Harry
                              thanasisT 1 Reply Last reply Reply Quote 0
                              • thanasisT Offline
                                thanasis Bronze Member @HarryS
                                @HarryS said in weather widget not updating:
                                Hello,
                                Thanks, Harry
                                i have to say it is indeed a lot better… still i had to synch 3 times today to get it update but that was the only time i had to do so
                                E 1 Reply Last reply Reply Quote 0
                                • E Online
                                  elbee @thanasis
                                  It’s still wobbly.
                                  The easiest way to see is in the morning. Sometimes my watch says it synced 2 hours ago and sometimes it says 9 hours ago (and in the last case doesn’t show any weather forecast until I force close the suunto app and start it again)
                                  thanasisT 1 Reply Last reply Reply Quote 1
                                  • thanasisT Offline
                                    thanasis Bronze Member @elbee
                                    @elbee indeed …
                                    I noticed that too . Still seems better than before .
                                    • X Offline
                                      Xyrics21 @thanasis
                                      This post is deleted!
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
