    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto race alti & baro
    Scheduled Pinned Locked Moved Suunto Race
    17 Posts 12 Posters 1.9k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Silviu Adrian MoiseS Offline
      Silviu Adrian Moise
      Hello, I hope you are well!!
      So, since a few weeks ago my Suunto race goes crazy with altitude. It is adjusting good with fusealti (gps), but then it goes up and down even if I stay still. It does the same also if I adjust it manually. Not only a few meters, sometimes goes to + 100 or - 100m when is supposed to be 3m .
      I tried the soft reset and also the hard reset and still the same problem. Anyone experienced similar issue? Or any recommendation on how to fix it?
      Thank youu!! And happy trails 😉
      GiPFELKiNDG claudioteresoC Clément LavabreC 3 Replies Last reply Reply Quote 2
      • GiPFELKiNDG Offline
        GiPFELKiND Silver Members @Silviu Adrian Moise
        @Silviu-Adrian-Moise sounds like a defective Sensor! I would prefer to open a suunto Service ticket for repair in guarantie!
        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, 9 Baro, 9 Peak, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) AndroidđŸƒđŸŒđŸ§—đŸš”
        Silviu Adrian MoiseS 1 Reply Last reply Reply Quote 0
        • claudioteresoC Offline
          claudiotereso @Silviu Adrian Moise
          @Silviu-Adrian-Moise try water with a bit of soap for a couple of hours
          It solved by baro problems (but mine was stuck in the same altitude
          Suunto Race Midnight 2.48.16
          Android app 6.5.9 on Samsung A52 in Portuguese
          Silviu Adrian MoiseS 1 Reply Last reply Reply Quote 1
            Silviu Adrian Moise @claudiotereso
            @claudiotereso thank you for the reply. I tried it but still the same problem 😱
              Silviu Adrian Moise @GiPFELKiND
              @GiPFELKiND thanks for the reply!! Yes, I am in contact with them to see what’s wrong. But I can’t send it right now, I am in the middle of big training block
              Mff73M 1 Reply Last reply Reply Quote 1
              • Mff73M Offline
                Mff73 @Silviu Adrian Moise
                Did you try a fridge test?
                https://forum.suunto.com/post/42684
                It may give some more proofs for a faulty sensor (once sure you have well cleaned the sensor with warm water, etc
                Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                Suunto Vertical all black
                Wife : S9PP
                SA: Always the latest beta :)
                Android 13, Galaxy S205G
                • T Offline
                  TitaniumDave Bronze Member
                  My Race works the same way. I honestly think the altitude was temperature sensitive, and there is even mention of this in some of the manuals for some Suunto plus apps. I don’t pay much attention to it though use it though as I live in a very flat place, I only care about barometric pressure and that does not vary.
                  • S Offline
                    spardic @TitaniumDave
                    @TitaniumDave yes mine is the same. I have done quite some trials and every time temperature does affect the altitude. Once I put it on my hand altitude starts decreasing slowly as the watch warms up. If I then place it back on a table, the altitude starts increasing again. Same with wind, impossible to get a good altitude track.
                    I am using the Race in stainless steel and black. Perhaps the titanium version is more stable? Who knows 🙂
                    I tried and tried to get a good stable altitude reading, but now starting to realize I am battling this for nothing 😆
                    the_ultramanT Stefano M64S 2 Replies Last reply Reply Quote 0
                    • the_ultramanT Offline
                      the_ultraman @spardic
                      @spardic I tried everything. But the same problem has been going on for months. I think it’s a software problem.
                      • Ɓukasz SzmigielƁ Offline
                        Ɓukasz Szmigiel
                        If you’re wondering why altitude reading changes with the temperature, this might be helpful:
                        https://airplaneacademy.com/why-and-how-much-temperature-affects-altimeter-readings/
                        S9PP 2.50.26
                        Stefano M64S 1 Reply Last reply Reply Quote 1
                        • Stefano M64S Online
                          Stefano M64 Silver Members @Ɓukasz Szmigiel
                          @Ɓukasz-Szmigiel said in Suunto race alti & baro:
                          that is related to the air temperature, not the temperature of the sensor that changes depending if you wear the watch or not
                          Suunto Vector . Vector HR . Core . Race & Race S
                          Ɓukasz SzmigielƁ 1 Reply Last reply Reply Quote 0
                            Ɓukasz Szmigiel @Stefano M64
                            @Stefano-M64 the internal sensor of the watch can’t measure the ambient temperature without it being influenced by the body heat. If you’re going to cycle between having a watch on your hand or on the table or on the handlebar, its altitude readings will change due to changes of internal sensor’s temperature.
                            This is why there’s fusedalti, but it can’t work reliably if the watch temperature fluctuates abruptly.
                            S9PP 2.50.26
                            Stefano M64S 1 Reply Last reply Reply Quote 0
                              @Ɓukasz-Szmigiel yes, I know, but the link you shared has nothing to do with that
                              • PrenjP Online
                                Prenj
                                I think that the algorithm that changes from baro to alti mode automatically is not doing its job good enough. I have no way of knowing this for sure, but my guess is that it’s not the same algorithm that is used in other watches. I had much better results outside of activity with Suunto 9 Peak, Suunto 9 baro and ambit3 peak.
                                I wear my Race 24/7 and almost every morning I see altitude almost 50m more than the night before. During the activity, it’s very good, altitude is mostly spot on, but I have also seen crazy ascent values (like more than 50% more) few times (but that is not so uncommon with Suunto watches I guess).
                                Suunto Race
                                  Stefano M64 Silver Members @spardic
                                  @spardic said in Suunto race alti & baro:
                                  BTW, I tested that on my Race, found no differences in both altitude and pressure
                                  • ClĂ©ment LavabreC Offline
                                    Clément Lavabre @Silviu Adrian Moise
                                    @Silviu-Adrian-Moise Hello, I’ve had the same problem since yesterday, the altitude is going crazy even when stopped, and counting the ascent. And not just when active, even when staying at home without moving the altitude goes up and down. I already had the problem several months ago, and after trying everything, I had to fight with Suunto to get a replacement. So now I’m doing a test today, and it’s going back to the store.
                                    • D Offline
                                      datzkey
                                      Hello everybody
                                      Same trouble to me: 120 meters of ascending instead of 2 meters. I’m totally disappointing. I don’t have warranty because I purchased used watches. But still believe that it is a software trouble.
                                      Does anybody resolve the issue successfully?
                                      And what would you say about software downgrade, maybe it helped somebody?
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
