    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    What's wrong with my Suunto Ocean
    Scheduled Pinned Locked Moved Suunto Ocean
    7 Posts 6 Posters 1.8k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      snajperist
      Watch was bought 2 months ago. So far I’ve experienced several issues that are quite annoying.
      No-fly icon - I never did scuba diving but this red airplane icon appeared after 7 days of use. I tried to restart, shut down, but nothing works. Icon is still there.
      Heart rate - one time before going to sleep, it showed 140 bpm. I was lying and I thought I was having a heart attack. But after restart it showed normal pulse of 60-70 bpm. Happened one more time and I had to restart it.
      Altitude correction - takes 10 minutes outdoors and usually fails. It showed 7m when I was at sea level (my hand was literally 0.2m above the sea surface)
      Sleep - yesterday I was watching TV for 1 hour, then I was active for at least 30 minutes before going to sleep. Everything was counted as if I were sleeping.
      Steps - exactly 3 steps from chair to couch, it counts 7 steps plus 3 after I sit down. So 10 instead of 3 steps.
      Compass - needs calibration almost always before using.
      Shutdown - after shutting down, time is restarted to Jan 1 until I sync it with phone. Should it at least count time while being off, I mean it’s a watch…
      Really don’t know if something is wrong with product I got. It wasn’t cheap and I expected such issues would never happen.
      J V Gilles van der HaveG 3 Replies Last reply Reply Quote 1
      • J Offline
        Jonathan C Silver Members @snajperist
        @snajperist it helps to understand how most of these aspects work in the first place.
        With the exception of the no-fly icon I can attempt to explain the rest.
        Heart Rate
        Suunto is known to not have the most reliable OHR sensors, but even if it does it’s fairly easy to pick up the wrong signals. Chest straps are much better but not foolproof either. In that case the most reliable HR sensor is the pulse check.
        Altitude
        Automatic correction uses GPS which is not very accurate for vertical positioning. Calibrate manually to known elevation.
        Sleep
        According to the manual, “Suunto Ocean tracks your sleep based on accelerometer data.” If you have been very idle during your TV session it is possible that the 30-minute activity could be treated as an awake period. Setting a sleep schedule on the watch that matches your own should anecdotally improve tracking accuracy.
        Steps
        Again, estimation based on accelerometer data. Suunto has a tendency to overshoot in the past but recent software seems to try make this more realistic.
        Compass
        Any device is subject to magnetic interference so ideally you would want it calibrated before every serious use case.
        Shutdown
        I agree with you on this.
        Current: Ocean, Vertical Titanium Solar
        Past: 9 Baro, Spartan Ultra, Ambit3 Peak Sapphire
        • V Offline
          Vlad_Aussie @snajperist
          @snajperist said in What's wrong with my Suunto Ocean:
          No-fly icon
          Hey, I have same issue with no-fly icon that appeared a few days ago. I didn’t dive, dive logs are empty. I use Suunto watch for 2 months. It may be this icon appeared soon after my watch battery went down and the watch shutted down. Agree with you it is annoying as no logics behind it and impossible to get rid of it.
          S 1 Reply Last reply Reply Quote 1
          • S Offline
            Scubadiver88 @Vlad_Aussie
            @Vlad_Aussie
            I also have issue with no-fly icon it appeared yesterday for no reason. No diving for 2+ months!!!
            • Gilles van der HaveG Offline
              Gilles van der Have @snajperist
              @snajperist
              Also have the no-fly icon with zero dives made. Just got it a couple of weeks and it appeared after it was both in ‘airplane’ mode and ‘energy saving’ mode for 2 days.
              Very annoying and unnecessary.
              Also was unpleasantly surprised with the date and time reset after shutdown.
              Gilles van der HaveG 1 Reply Last reply Reply Quote 0
                Gilles van der Have @Gilles van der Have
                @Gilles-van-der-Have said in What's wrong with my Suunto Ocean:
                @snajperist
                Just had contact with Suunto Support, they advised a soft reset: Press and hold all three buttons for 12 seconds and release them to perform a soft reset.
                After reboot it was there but disappeared after a few seconds. Woohoo! 🥳
                They also confirmed they are aware of the problem and are working on it. Hopefully it’s fixed in the next update.
                D 1 Reply Last reply Reply Quote 0
                • D Offline
                  dreammaster @Gilles van der Have
                  I have a similar problem, first my watch ran out of battery (it ran out) and after I charged it, “no fly time” went crazy:
                  Today I saw that there was an update, I installed it, but the problem with “no fly time” still persists. I tried a “soft reset”, but it didn’t help. Any ideas how to solve this problem?
                  Thanks in advance
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
