    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto+ apps max 2 apps enabled for workout
    Scheduled Pinned Locked Moved Suunto Vertical
    2 Posts 2 Posters 520 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tomas HolcekT Offline
      Tomas Holcek
      Hi,
      Is there any plan for Suunto to allow more Suunto+ apps to be activated simultaneously? I don’t understand why Suunto limits it to a maximum of two active apps. For instance, if you’re using a Stryd, which takes up one slot, you’re left choosing between ZoneSense or Climbing for the second. Does this limitation suggest that Suunto is using older hardware that can’t support running 3-4 apps at the same time?
      Are the same limitations present on the Suunto Race as they are on the Suunto Vertical?
      • EgikaE Offline
        Egika Platinum Member @Tomas Holcek
        @Tomas-Holcek Noone here will be able to share if there are plans regarding this limitation.
        Your other question is easy to answer though:
        Race and Race S have the same 2 S+ limitation like Vertical and other models.
        Register Login
        • First post
          Last post
        Suunto Terms | Privacy Policy
