    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro - backlight will not switch off
    3 Posts 2 Posters 489 Views 1 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      Neil Winston
      I’ve got an S9 Baro and have been using it without probs for about 3 years but suddenly last week the backlight would not switch off. It was in raise to wake mode. I disabled both raise to wake and standby but the backlight remains switched on permanently, even if I go to low power mode it stays on albeit very dimly.
      I sent the log to Suunto via the app, the ID was: 3597182068500. A soft reset didn’t change anything and I don’t really want to do a factory reset unless absolutely necessary but that seems to be the only remaining option.
      Hopefully a Suunto admin will see this post and offer me advice. Or perhaps another user will have suffered the issue and found a solution?
      inkognitoI 1 Reply Last reply Reply Quote 0
      • inkognitoI Offline
        inkognito Platinum Member @Neil Winston
        @Neil-Winston Long-press the middle button and check that backlight is off there…
        SV: fingers crossed :D
        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
        Despite some pretty bad luck, I still love Suunto!
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          Neil Winston @inkognito
          @inkognito OMG that is hugely embarassing and a huge relief at the same time, thank you so much. I can’t believe I’d never noticed that option in the Shortcuts menu 🤦
          Register Login
          • First post
            Last post
          Suunto Terms | Privacy Policy
