    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Strange Display Behaviour
    Scheduled Pinned Locked Moved Suunto Race S
    10 Posts 6 Posters 1.6k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • VoiGASV Offline
      VoiGAS Gold Members
      Hi, I think I found two hidden display features. Settings to reproduce it for the training. Display AOD on, Brightness medium, lift to wake off.
      Now the strange thing: I would have thought now it is necessary to push a button to activate the watch, but there are two other methods:
      1. Touch ( don’t push) the middle button/crown. The light goes on
      2. Expose it to strong light ( window or torch) and the brightness increases!
      So it seems like the Race S crown is touch sensitive and also has some kind of ambient light sensor. Strange, but that gives us great posiibilities for future firmware if its true and not just a spooky effect on my model
      Edit:
      Ambient light sensor seems to be a known feature at least in the Race:
      https://forum.suunto.com/post/130374
      Still, the “Touch Crown” could be a new finding…
      Race S
      Vertical Titanium Solar
      Ambit3 Vertical
      Eon Core
      herlasH 1 Reply Last reply Reply Quote 0
      • herlasH Offline
        herlas Silver Members @VoiGAS
        @VoiGAS AFAIK there’s no such physical light sensor, it’s software-based on the SR and SRS.
        SRS Ti
        SRun (primarily road runner so testing SRun is a must ;))
        VoiGASV 1 Reply Last reply Reply Quote 0
        • VoiGASV Offline
          VoiGAS Gold Members @herlas
          @herlas How could such a thing work based on Software? It reacts on direct light from a torch indoor
          Race S
          Ambit3 Vertical
          Eon Core
          • herlasH Offline
            @VoiGAS weird right? I read somewhere Suunto AMOLED watches do not have it, rather, it’s controlled by software somehow. I can be wrong but at least there’s no evident light sensor on any part of the screen like in SV and other MIPs.
            SRS Ti
            • F Offline
              far-blue
              I’m pretty sure the Race S does have some sort of light level sensor. I’ve dusted off my head torch now the nights are drawing in and when the torch shines straight on the display it appears to get brighter to compensate.
              • BastienhereB Offline
                Bastienhere Bronze Member
                I’d say 99% of AMOLED smartwatches or sport watches would have an ambient light sensor, otherwise the auto brightness function wouldn’t exist haha.
                Although not common that the screen would turn on from a bright light - i think it’s a pretty cool function.
                As for the touch crown, pretty interesting
                • H Offline
                  halajos Bronze Member @herlas
                  @herlas not having a light sensor that’s visible from outside doesn’t mean the Race doesn’t have one. It may be built right into the display. It’s just impossible to sense light without a light-sensitive physical device 😊
                  • Stefano M64S Offline
                    Stefano M64 Silver Members
                    The brightness of the Race adapts to the ambient light, so, yes, there is definitely a light sensor somewhere, likely behind the amoled screen.
                    Suunto Vector . Vector HR . Core . Race & Race S
                    VoiGASV 1 Reply Last reply Reply Quote 1
                    • VoiGASV Offline
                      VoiGAS Gold Members @Stefano M64
                      @Stefano-M64 Too bad it doesn’t adapt enough to make the AOD visible during daylight. But maybe a software update can solve this, it even doesn’t react to the brightness setting.
                      But one can use the other hidden sensor for a workaround. Instead of using the painfully slow raise to wake I managed to wake it by touching the Touch crown with the back of my hand. Its a little strange and only works with the watch sitting low. But it activates the screen much faster.
                      Race S
                      Ambit3 Vertical
                      Eon Core
                      • VoiGASV Offline
                        VoiGAS Gold Members
                        Update for the light sensor: If you have the sun on the side you wear the watch (like running west at noon if you are wearing it left) the light sensor adapts very well. Maybe even overadapting to the sun, the AOD is really bright in this cases.
                        Running back east (watch is not in direct sunlight) it is underadapting and very hard to read.
                        So I think light sensor and display could do a lot better if this algorithm is tweaked a little bit to respond better to daylight
                        Race S
                        Ambit3 Vertical
                        Eon Core
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
