    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Vertical treadmill mode.
    Scheduled Pinned Locked Moved Suunto Vertical
    7 Posts 5 Posters 998 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      adam_mayes
      Hi guys,
      Ive had my Vertical for a month or so now.
      Had no problems with running outside with GPS.
      I’ve done a few runs in treadmill mode, the first couple being very accurate with paces and distance. The last couple of days all the runs are pretty far out. When I edit the distance at the end to match treadmill distance the distance and overall pace changes, however all the lap paces within the workout still remain the same. When this goes to Strava it shows the adjusted distance and pace on the main page, then the lap paces and distances dont add up to the overall numbers. The main problem is this would be all of my data would end up incorrect when I use the treadmill. My vo2 max , predicted times and fitness will all be off.
      I hope this makes sense and that there is an easy fix for this.
      Thanks in advance
      Adam.
      A VoiGASV 2 Replies Last reply Reply Quote 0
      • A Offline
        adam_mayes @adam_mayes
        I forgot to mention I also have a stryd foot pod. Not sure if anyone has had good results using the stryd and vertical? To be honest I’ve got no idea what’s going on with the stryd with this watch. The stryd website says the vertical doesn’t take pace and distance from stryd, but I’ve read other places it does. At the moment it seems to make no difference if the stryd is set as a foot pod or not, the pace showing on the watch is around a minute and a half a mile off, with no way to correct it. Maybe I would have been better off with a coros pace 3 for under 200 quid?!
        pilleusP 1 Reply Last reply Reply Quote 0
        • pilleusP Offline
          pilleus @adam_mayes
          @adam_mayes
          NPE Runn treadmill sensor is your friend and you will have accurate results on your Vertical/Suunto app and fun! 😄
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          • VoiGASV Offline
            VoiGAS Gold Members @adam_mayes
            @adam_mayes I have the same problem with the Race S (without footpod). The treadmill mode really needs a little bit more attention
            Race S
            Vertical Titanium Solar
            Ambit3 Vertical
            • G Offline
              giuliosq
              me too, the stats like pace and distance (without any device but the watch itself) are totally out of synch with the ones the treadmill says. Where apple watch is perfectly stating the same stats
              • EgikaE Offline
                Egika Platinum Member @giuliosq
                @giuliosq have you adjusted the distance after the run? Speed and other data should adjust accordingly
                t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                G 1 Reply Last reply Reply Quote 0
                • G Offline
                  giuliosq @Egika
                  @Egika just tried it today twice, after a treadmill 1k run my watch was at 1.5 k so adjusted it to 1k and tried it again but vene second time it was out of 200 meters ill try again tomorrow. Thanks!
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
