    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Heart Rate Belt - Heart Rate too high
    Scheduled Pinned Locked Moved Accessories and other products
    29 Posts 14 Posters 7.0k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SuperFlo75S Offline
      SuperFlo75 Silver Members Bronze Member
      Hello guys, today I saw a really crazy behavior of the heart rate during my run. I used my Suunto heart rate belt the first time after many month of using the OHR. As usual I gave water on the skin under the belt.
      When I started the sports mode, everything seemed to be normal, the heart rate was about 80/min as I expected to be normal. After beginning my run, the heart rate was extremely high, over 200/min, much higher than expected. My feeling was good, and I expected a heart rate of about 150/min… after about 15 minutes, I did a little break the get my pulse at the arteria carotis, I counted and used my stop watch of the phone… the heart rate was about 140/min, and the watch showed about 210/min 😡 after that I continued my run, and a few minutes later I saw the heart rate on the watch with a frequency of 150-160 as expected…
      Can anybody explain me what happened there? I thought the heart rate belt is better than the OHR? Are there any factors that explain a too high heart rate?
      I don‘t have any problems with my heart and no atrial fibrillation or something like that which would cause a difference between EKG and peripher pulse…
      I’m looking forward to your opinion!
      Suunto Vertical 2 Titanium Sage
      Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
      Suunto Wing
      Suunto 9 Peak Pro Titanium (owns my wife now)
      Suunto Spartan Ultra
      SA iOS 3.12.0 (22937)
      Instagram @superflo75
      VoiGASV Brad_OlwinB 2 Replies Last reply Reply Quote 1
      • VoiGASV Offline
        VoiGAS Gold Members @SuperFlo75
        @SuperFlo75 I had the same or a similar problem with my belt. After cleaning and a massage of the belt everything worked well again. Maybe it works for you too
        Race S
        Vertical Titanium Solar
        Ambit3 Vertical
        GiPFELKiNDG 1 Reply Last reply Reply Quote 1
        • GiPFELKiNDG Offline
          GiPFELKiND Silver Members @VoiGAS
          @SuperFlo75 had similar thing, opened the battery Box, put a new battery in and all works fine again 😜
          If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
          • ? Offline
            A Former User
            Usually when the belt behaves funky it’s a battery issue, or the belt is old. Try a new battery and see if it helped : )
            • J Offline
              jussim Bronze Member
              What kind of “mileage” do folks get out of the battery in the belt? Say you train for a neat 500 hours in a year - and always use a belt - how often do you change the battery? Yearly? More often?
              Can’t comment on my own experiences since I’ve had the belt for less than a year now and use it mainly on just workouts and races so maybe 2-3 times a week 🙂 Just curious!
              9PP since 09-2025.
              Mff73M 1 Reply Last reply Reply Quote 0
              • Mff73M Offline
                Mff73 @jussim
                @jussim
                not mileage but time
                @Mff73 said in HR low battery alert:
                yesterday i made the first run with my Suunto HR Belt that reach 0% battery level 👋
                HR records are still nice and mesurments are true (at least twice in the move when I stop to check with fingers on the neck 😉 )
                i will try to push it as long as I have metrics on the watch.
                FYI, this battery totalize 380 hours of recordings (so some extra hours when plugged and moves not started).
                SSU (retired), SV1, SV2
                Wife : S9PP
                SA: Always the latest beta :)
                Android + Galaxy S205G
                • A Offline
                  alebalbis
                  I have exactly the same problem that @SuperFlo75 is having, when using my Suunto strap the heart rate spike almost instantly from 80 to 160 but after a few minutes the HR comes back to normal.
                  But today it was a mess, HR was very irregular at the beginning and then increased to near 200 and stayed there for several minutes.
                  It was so bad that for the first time zonasense was not registered and it is not shown in the graph.
                  I always moisten the strap and I pair the sensor before running.
                  I will try changing the battery (it is not so old) and if the problem persist I’ll contact the Suunto customer service.
                  M F 2 Replies Last reply Reply Quote 0
                  • M Offline
                    Mauerwegler @alebalbis
                    What colour does the contact area on the strap have? My all black strap (with black contact patch for the sensor) also behaved like that after half a year of usage (with 8 sessions per week maybe). I then learned in this forum that Suunto has changed something and the „good“ straps are black with grey contact patch. There are threads about this in this forum.
                    Vertical All Black
                    Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
                    Vector
                    iOS Suunto App (beta)
                    SuperFlo75S 1 Reply Last reply Reply Quote 4
                      SuperFlo75 Silver Members Bronze Member @Mauerwegler
                      @Mauerwegler this sounds interesting, I didn’t know this. I will look at the colour at home. But I bought a new strap, because a new Battery didn‘t solve the problem. With the new strap, the Heart rate seems good as expected… but I have still problems with ZoneSense because I still don‘t see the ZoneSense metrics of all trainings with the belt… 🙈
                      Suunto Wing
                      • Pasi80P Offline
                        Pasi80
                        Hi.
                        Anybody still have problem with Suunto heart rate belt/strap?
                        I have Suunto Vertical and heart rate belt. Problems with heart rate monitoring (show totally wrong heart rate) start 2024 summer and finally Suunto changed both devices (vertical/belt).
                        4 months new watch/belt work correctly, but after that the same problems start again.
                        The problem have not gone away so next week I will send both (vertical/belt) to maintenance (warranty).
                        SuperFlo75S 1 Reply Last reply Reply Quote 0
                          SuperFlo75 Silver Members Bronze Member @Pasi80
                          @Pasi80 actually I have no problems with SV and belt… but I bought a new one after the problems I had when I opened this thread
                          Suunto Wing
                          Pasi80P 1 Reply Last reply Reply Quote 0
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @SuperFlo75
                            @Pasi80 does the belt have the grey color between connectors or black? The older belts (black around sensor connector) are not as robust and the connection degrades. A second issue if wearing a tech shirt and you don’t sweat enough static can build and affect reading HR. I always wet the belt under running water not just my skin. That keeps the belt wet enough until I sweat so static does not build. Even the new belts only last I to 1.5 years for me.
                            Vector/T6c/Vertical 2 Ti
                            Pasi80P SuperFlo75S 2 Replies Last reply Reply Quote 1
                            • Pasi80P Offline
                              Pasi80 @SuperFlo75
                              @SuperFlo75 okay… So after you bought a new one you haven’t got any problems (if I understand right)
                              • Pasi80P Offline
                                Pasi80 @Brad_Olwin
                                @Brad_Olwin Can you send a picture so I can be sure what “area” you mean (gray or black)? I can check it later when I get back home.
                                Also I always wet (enought 😉) my heart rate belt before exercise. My Garmin Fenix 5 and Garmin heart rate belt working with no problems.
                                I have weared both SV + belt & Garmin Fenix 5 + belt -> Garmin gave correct pulse but Suunto is not…
                                  SuperFlo75 Silver Members Bronze Member @Brad_Olwin
                                  @Brad_Olwin The new belt is the grey one, and the old was the black one. But the old belt was about 3 years old… I always make the belt wet before using it, and I wash it with clear water after using… but now, with the new one, everything is good
                                  Suunto Wing
                                  Pasi80P 1 Reply Last reply Reply Quote 2
                                    @Pasi80 yes, that‘s right
                                    Suunto Wing
                                      @Pasi80 I think he means this area…
                                      Suunto Wing
                                      • F Offline
                                        flyinono @alebalbis
                                        @alebalbis same for me, exactly the same problem withe the HR spike at the beginninng. I have the belt with the grey area which seems to be the latest.
                                        • Pasi80P Offline
                                          Pasi80 @SuperFlo75
                                          It seems to be black… So it is old series. Need to take contact to Suunto suport. Thanks
                                          • Pasi80P Offline
                                            Pasi80 @SuperFlo75
                                            Thank you. Mine seems to be black. I will take contact to Suunto suport
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
