    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Higher battery consumption
    Scheduled Pinned Locked Moved Suunto Race S
    16 Posts 7 Posters 3.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      orzechszek
      Hello,
      Does anybody noticed higher battery consumption? I didn’t change anything recently like light, watchface etc… and for a night I have quiet mode set. I’ve noticed it when battery percentage has changed from about 32% to 12%… quite fast. I’ve decided to charge it fully but it happened again. When I was sleeping it consumed ~1% of a battery. Earlier
      before was just few. Such behavior happened suddenly. I don’t remember any specific steps I’ve made.
      Watch: Suunto Race S
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Online
        isazi Moderator @orzechszek
        @orzechszek a fix will come for battery drain, in one or two weeks.
        Did you use navigation during activity? Have you already rebooted your watch?
        Blog: isazi's home
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          orzechszek @isazi
          @isazi Yes, I was using navigation during previous activity. I didn’t reboot my watch yet. Should I send logs ?
          • isaziI Online
            @orzechszek not necessary to send logs, for the next couple of weeks reboot your watch after using navigation
            Blog: isazi's home
            O 1 Reply Last reply Reply Quote 2
            • O Offline
              orzechszek @isazi
              @isazi Thanks for a tip.
              • F Offline
                far-blue
                I was just about to post the same question. When I first received my Race S the battery was lasting ~ 6 days for me including all my activities but now it’s down to 3 days and about 4 hours of activities before getting to 10%. I’ve recently used navigation on a couple of runs to see if the local hills are big enough to trigger the climb screens (answer - no) but the timing makes sense.
                I assume the new firmware that’s about to drop is going to trigger a reboot. Will that firmware (the one with the downloadable watch faces Suunto announced in the app a couple of days ago) also have the battery drain fix, do you know?
                isaziI 1 Reply Last reply Reply Quote 1
                • isaziI Online
                  isazi Moderator @far-blue
                  @far-blue no, it will not, battery drain fox will come a couple of weeks later as the fix is still being tested
                  Blog: isazi's home
                  • F Offline
                    far-blue
                    Just dropping a note to confirm that after a soft reset (i.e. turning it off and on again) my Race S is back to normal battery burn behaviour across all my activities and daily tracking. I’ve disabled even breadcrumb navigation when starting all gps-based activities (just to be sure) and all seems good. Looking forward to a fix, of course, and also as an aside hoping an option to ‘remember’ navigation being off on a per-activity profile bases will be added soon 🙂
                    If help is needed with tracking down the bug I am always willing to lend a helping hand 🙂
                    • F Offline
                      far-blue
                      I don’t suppose there’s any news on the hot fix for the high battery drain after using routed navigation, is there? I don’t use it often (mainly just my long runs so once a week) but it would be nice not to have to remember to soft reset after each time 🙂
                      AntoineA 1 Reply Last reply Reply Quote 3
                      • AntoineA Offline
                        Antoine Bronze Member @far-blue
                        @far-blue said in Higher battery consumption:
                        Under 1 week i hope … 🤞
                        Suunto vertical solar
                        Coros arm HRM / Suunto wing 2
                        Android A55 Samsung
                        Suunto App latest official update
                        SvenSchroeterS 1 Reply Last reply Reply Quote 1
                        • SvenSchroeterS Offline
                          SvenSchroeter @Antoine
                          @Antoine I heard the end of September being mentioned here on the forum (as an approximate timeframe). Lets hope by the end of the week there is a push. But it all depends if the kinks get ironed out and if the root cause of the issue has been found or not. Only time will tell.
                          Suunto Vertical Ti Solar (Daily)
                          Suunto Race (Wife Daily)
                          Retired: Suunto Ambit3 / Ambit / Core
                          https://www.strava.com/athletes/142980701
                          • S Offline
                            sracer Bronze Member
                            I bought a Race S in the beginning of August and immediately discovered quite pronounced battery drain: even with the watch sitting on the table with everything off (AOD, 24/7 heart rate tracking, sleep monitoring, WiFi, weather complications), the daily battery drain was anything between 16-20%. Nothing I tried (including soft reset, battery calibration, hard reset, firmware reinstallation, phone app reinstallation) didn’t change the behavior.
                            I sent my watch back to Suunto and received a new, unboxed watch in 10 days (I live in Finland). The new watch has been behaving as expected from the day one, consuming only 3% (or less) a day with similar sitting-on-the-table scenario. On the wrist, with AOD off (Raise to wake), Sleep monitoring and 24/7 heart rate tracking on, the consumption varies depending on the daily activity, but is typically in the range of 11-16%. For example, last full charge was made on Sunday-Monday night at 0.11 and now, Tuesday at 15.20 (in 39 hours) it has dropped to 82% (no excercises and minimal daily activity due to catching cold, desk job).
                            Key takeaway: There actually might be faulty units out there or the firmware bug hits some units quite a bit heavier than others for reasons unknown (for us, let’s hope Suunto engineers have better understanding…).
                            I’m now a happy camper and really enjoy my watch 🙂
                            Mirek_RM 1 Reply Last reply Reply Quote 2
                            • Mirek_RM Offline
                              Mirek_R @sracer
                              @sracer Thanks for sharing. I have Race S since last Friday and with 1-1,5h daily run with medium brightness, AOD enabled it holds only 2-2,5 days. When I need to adjust something in menu energy is consumed very quickly. About 10-12% is used at night when display is completly off…
                              This watch last less then half it should be according to Suunto.
                              After your post I am wondering if should do same and ask for another piece.
                              I received watch made in China. Your proper specimen is also made there?
                              S F 2 Replies Last reply Reply Quote 0
                              • S Offline
                                sracer Bronze Member @Mirek_R
                                @Mirek_R Both of my watches are made in Finland. Your battery consumption during the night sounds a lot like my first one…
                                Mirek_RM 1 Reply Last reply Reply Quote 0
                                • Mirek_RM Offline
                                  Mirek_R @sracer
                                  @sracer I spoke with Suunto support. They told me to turn everything off and make a soft reset. Then observ watch behaviour. If nothing changes then hard reset.
                                  In 3 hours without interactions -5% it seems tommorow I will make hard reset but first I have to wait until it runs out of energy.
                                  • F Offline
                                    far-blue @Mirek_R
                                    @Mirek_R Try charging it fully then doing a soft-reset (hold the upper button for 12 seconds) and see if it fixes the drain issue. The main trigger for the bug that drains the battery seems to be when you start an activity with navigation (with a route, not just breadcrumb). A soft reset fixes the issue until the next time you use a route. If the battery drain is still there after a soft reset, talk to customer services and you can prob. send the watch back for a replacement or repair.
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
