Nfc
Does Suunto Ocean have na NFC for Google Pay?
@wlubicki No
@Desdinova Polar do a 22mm NFC compatible watch strap you could use,
@Desdinova Would this survive scuba diving though?
@Sandyzoo yep.
@Ze-Stuart do you have any specs-link of water / scuba diving resistance for the strap?
thanks man! -
@gerasimos no, but there are no powered electrical components (passive NFC antenna), and I imagine no air due to the moulding, so no compression/decompression stressing the plastic. Just a lump of relatively incompressible solids.
My bigger concern would be it not being a diving strap, is it big enough to go over a wetsuit? And as others have raised about the Ocean’s strap, if one of the strap retention pins fails, the whole watch falls off.
With your input, this post could be even better đź’—
Register Login
