    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Calories wrong in app + low estimate
    Scheduled Pinned Locked Moved Suunto Race S
    12 Posts 2 Posters 2.1k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DianeBD Offline
      DianeB
      Hello,
      I am 58kg for 171 cm. I ran today in endurance pace (60-70% FCM) 15km in 1h20, that is 5’20 min per km.
      The watch says 739 calories for the run, am I correct to understand it includes BMR ? Because it said 660 active calories in the calories widget after the run and the active calories in the app is also lower.
      Also, the app has a total wrong it counts only active calories (see screenshot, only 681 total). Is there a bug ?
      While it was an endurance pace and I am quite trained, this estimate seems a bit low to me. Does anyone have a similar experience?
      • T Offline
        The_77 Silver Members
        Firstly, calorie burn is estimated off HR zones, so if you’ve set specific zones then you’ll get better results. Fwiw this morning I was out for 1:22, with my max HR at 185, threshold low 160s, did five hill intervals mixed in at z4/z5 for 100s, averaged upper Z2 HR for 871 calories.
        As ever though, will vary based on you and your heart.
        As for in app calories, my active and BMR are obviously split, so not sure there:
        Suunto Spartan Trainer Wrist HR / 9PP Refurb
        DianeBD 1 Reply Last reply Reply Quote 1
        • DianeBD Offline
          DianeB @The_77
          @The_77 thank you. Yes I’ve set my zones, max HR is 196 for me. If I am correct, the 871 in your screenshot is active + BMR calories during your run yes ? Because your number of active cal for the day is lower than 871. And tbh, your estimate seem low too for your run for that duration with ascent on top of it 😉
          T 1 Reply Last reply Reply Quote 0
          • T Offline
            The_77 Silver Members @DianeB
            @DianeB slightly tired morning run due to going meteor hunting suppressed HR maybe? 😅 And yes, I’m guessing the active split is slightly under 871, if you run by the burner app, 4Kcal per g carbs, 9kcal/g fat, I get 718 kcal though with this chat about max HR I’ve just fiddled with it a tiny 3bpm 😁
            App display is a bug though, maybe clear cache if you’re on android to force it to re-sync properly.
            DianeBD 1 Reply Last reply Reply Quote 0
            • DianeBD Offline
              DianeB @The_77
              @The_77 sorry I did not understand your last reply
              • T Offline
                @DianeB if you’re on Android you can force the app to re-sync the watch by deleting the cache in app settings - on iPhone you have to uninstall and reinstall if you think you have a cloud issue with data.
                • DianeBD Offline
                  DianeB @The_77
                  @The_77 That I understood thanks for the tip. But it’s the whole paragraph about meteors and carbs I did not get 🙂
                  • T Offline
                    @DianeB ah, if you activate the burner Suunto+ App, if gives you the number of grams of Fat and Carbohydrates burnt as an estimation. Typically from memory, 1g of Carbs is 4kcal, and 1g fat is 9kcal. You can use that to work out your actual active calories for the activity, roughly.
                    As one other note, that calorie count at the top is slightly counterintuitive, as it is the total active calories for the day, not just your activities, which you’d suspect if you just glanced at it since it’s next to the number of activities and time spent in activity.
                    The meteor part was that body tiredness induces suppressed HR, meaning it won’t go as high as if I was fresh, and I may have burnt less calories than a fresh run. But that was more of a guess, since I went to watch the Perseid meteor shower last night.
                    DianeBD 2 Replies Last reply Reply Quote 0
                    • DianeBD Offline
                      DianeB @The_77
                      @The_77 wow, all makes sense, thanks for the information ! And I hope the meteor night was worthy, I’m sure it was !
                      • DianeBD Offline
                        DianeB @The_77
                        @The_77 ah, Suunto plus is not compatible with Suunto race it seems. But thanks I didn’t even know it existed
                        DianeBD T 2 Replies Last reply Reply Quote 0
                        • DianeBD Offline
                          DianeB @DianeB
                          Ah yes nevermind it is compatible ! Thanks for all the learning shared
                          • T Offline
                            @DianeB it absolutely should be, every single item on the Suunto+ store should be compatible with the Race S, obviously you need the external accessory for some like CORE sensor or so on?
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
