Indoor Climbing
Today I tested the SuuntoPlus app Indoor Climbing.
First the positive: attempts recognition is quit good
Now the negative: no data except number of attempts and time is shown
It’s a pity and I hope somebody correct it. I’m really looking forward for this app.
Tested also, same behavior
The creator of this S+ is @omunoz, so share feedback and changes/fixes might be done in future.
@omunoz : If you need further information, tell me.
M Mitch9 referenced this topic on
The ascension meters starts to view in the watch when arrive to a 3 meters , if you climb less of 3 meters no appear . Is normal in barometer Suunto metrics
@omunoz I climbed on a wall with more than 12 m and nothing appears.
@Mitch9
Hi you can say me the date ? Becauase Is updated om 01/07/2024Thanks
@omunoz i tested myself before the update then. I’ll test it again so !
@omunoz 07.07.2024
@Mitch9
You can send this information:
Clock model
Watch firmware
And how do you use the application and what is wrong with it?Thanks
@omunoz said in Indoor Climbing:
@Mitch9
Clock model
Watch firmware
Suunto Vertical Titanium Solar
FW 2.35.34
Description of the wrong behavior: look at the start post2nd watch
Suunto 9 Peak
FW 2.26.8
Description of the wrong behavior: look at the start post -
And fails in both watches ?
Hi ,
Can you do a small test that you can test with, I could go up 3 flights of stairs and back down again. Having the S+ on and just see if the values change.
I will do the same test today, Thanks
Regards
Could this threshold be decreased so the app would work for bouldering also?
@marbjo said in Indoor Climbing:
Hi,
Maybe no, beauase is how count Suunto the first meters later, count meter by meter.
Thanks
Register Login
