    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problem with the map the Suunto app transfer
    Scheduled Pinned Locked Moved Suunto Vertical
    11 Posts 3 Posters 1.3k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • V Offline
      Vertical_Blink
      Hello,
      Sorry for my english I’m french.
      Since yesterday I have a problem with my Suunto Vertical at the end of an activity (hike, running, trail running, bike) during the transfer to the Suunto app.
      The problem is that the map doesn’t appear when the activity is downloaded.
      I don’t understand because during the activity, all informations are ok (distance, elevation gain, speed). I have my position with the map behind and I can follow a direction.
      I restarted the phone and the Suunto too.
      I link a discussion about it on reddit with 2 pictures to explain.
      (https://www.reddit.com/r/Suunto/s/yhiWTywEBW)
      Any idea ?
      Mff73M 1 Reply Last reply Reply Quote 0
      • Mff73M Offline
        Mff73 @Vertical_Blink
        @Vertical_Blink
        Could you share a non working activity link?
        We could check if we could see your map in our app.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          Vertical_Blink @Mff73
          @Mff73 thanks for the reply. What kind of activity are you thinking (to be a non working activity).
          If you speak about the HR, I remove it for a run (https://maps.suunto.com/move/tjoensgauthier/666b3fc29b3a6601bf936ef4) it’s the same
          danklodD Mff73M 2 Replies Last reply Reply Quote 0
          • danklodD Offline
            danklod @Vertical_Blink
            @Vertical_Blink You can try to disconnect the watch on the phone and connect it again. Also you can try to delete local maps if the first one don’t help you.
            • Mff73M Offline
              @Vertical_Blink said in Problem with the map the Suunto app transfer:
              Your issue is not having “map” displayed on your activity in the app, right ? It is what i called a “non working” activity.
              in the link you shared, there is no map neither displayed in my app for your activity (neither on the web sites). Are you sure you enabled GPS in the sportmode AND wait for proper GPS fix ? I know you already wrote that yes, but just in case. This activity is 4minutes, 300m and 12 steps, just a test ?
              Wife : S9PP
              • V Offline
                Vertical_Blink @danklod
                @danklod I disconnected the Suunto from the application and reconnected it and I reloaded the map. I will see.
                • V Offline
                  @Mff73 the GPS is enable and I waiting several second after the fix green arrow of the GPS.
                  For the link, yes it’s a test. I link a other activity with the problem :https://maps.suunto.com/move/tjoensgauthier/666a003dbbce21691faabf2c
                  As you can see, there is a picture of a guy running but not a map with the activity like this one :
                  https://maps.suunto.com/move/tjoensgauthier/6667573ce1d73d089d90d502
                  • Mff73M Offline
                    @Vertical_Blink
                    Ok, so it is out of my simple user competency.
                    It doesn’t help, but it never happened to me.
                    Wife : S9PP
                    • Mff73M Offline
                      @Vertical_Blink
                      if you have an android phone and willing to have a look at the raw data that the watch sent to the app, you can make a dump of suunto app data https://forum.suunto.com/post/40800
                      and then find some files like here in the resultant folder.
                      https://forum.suunto.com/post/124093
                      you might see if the watch is having GPS values or not, and then the root “cause” might be precised
                      Wife : S9PP
                      • V Offline
                        I tried an another test with 3 pictures :
                        1 during the “run”, everything is ok.
                        The 2 others are at the end of the test, there is no graphic for the elevation (third picture), it’s the problem.
                        And for the second picture, it’s below all the resume, it’s the elevation again but with more information and it’s the same : no trend.
                        https://maps.suunto.com/move/tjoensgauthier/666c0f6089b99c0235a3066d?imageId=666c1048e28ce509d2c6da14
                        • Mff73M Offline
                          @Vertical_Blink
                          If you already soft reset your watch, if you are seeing green fixed arrow before launching activity, if you see your position on the map during activity, but nothing about GPS track in Suuntoapp after, I can’t help more.
                          Let’s wait for others.
                          Wife : S9PP
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
