    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Setting
    Scheduled Pinned Locked Moved Suunto Vertical
    3 Posts 3 Posters 418 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      brabirl
      I’ve been looking for a while but can’t find the right button.
      1. Sounds: I’ve turned off the sounds and set them to vibrate, but there’s still a sound when I get a call or a message? How can I turn it off?
      2. Brightness: I want the watch to turn off the display and only turn it on when I turn my wrist. Where can I find this setting?
      I hope someone can give me a tip on this.
      • Tami999T Offline
        Tami999 Silver Members
        1. Hold middle button or just go options-> General -> Sounds
        First option of sounds choose Turn all off - You won’t hear anything
        Second otpion is vibration - i got it ON, no sounds, only small bzzzz on Your wrist 😄
        Thrid option is alarm, You can set vibration, alarm sound or both.
        If You still got sounds, maybe try soft reset - Hold Middle button or go options -> General -> Scroll to end of list to turn off Your watch, to turn on, hold upper button like 12s.
        1. Hold middle button or just go options-> General -> Display
        First option here is actually brightness of Your menu for example, set what u like.
        Second option it makes Your screen always on display. Set it for NO (If u want only when move Your wrist)
        Thrid option here is wake up, set light or high, depends how much intense brightness should be when You turn wrist. choosing turn off will actually disable “turn it on when turn wrist”
        • EgikaE Offline
          Egika Platinum Member @brabirl
          @brabirl Suunto Vertical has a super low power MIP display that is always on. You can setup the cases, under which the background illumination comes on.
          The display itself only goes fully off when the watch is not worn or switched off.
          Register Login
          • First post
            Last post
          Suunto Terms | Privacy Policy
