    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    How many SuuntoPlus Apps in Cycling mode?
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    8 Posts 3 Posters 948 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      Chris Ki
      Hello, I have a Vertical (Steel), latest Siftware). I thought I could use two S+ Apps during training. It works for running but not for cycling. In Cycling Basic Mode I can either use Burner or Strava Relative Effort but not both. Ist it a bug or normal?
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Chris Ki
        @Chris-Ki should be two in all sport modes. Are you also using an S+ guide?
        Blog: isazi's home
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          Chris Ki @isazi
          @isazi no, but when I choose burner on the watch and move on to strava and choose it, I see that burner is deactivated and the other way round. No other S+ App is activated.
          • isaziI Offline
            @Chris-Ki not sure if it is these two apps in particular, I have other apps and not have that issue. Have you already tried rebooting the watch?
            Blog: isazi's home
            • C Offline
              Chris Ki @isazi
              @isazi Hi, I made a softreboot but the
              Problem still exists. It seems that the Burner S+ App is not working properly. When I activated it, leave the S+ Menue and reenter it, it is deactivated and the Menue shows, that only strava is active.
              • isaziI Offline
                @Chris-Ki quite strange, I cannot reproduce. Is the burner app misbehaving only in combination with Strava or all the times?
                Blog: isazi's home
                • C Offline
                  Chris Ki @isazi
                  @isazi OK I have tested it in other sport modes and in combination with other S+ Apps. Only Burner is the problem. When I choose Burner and another S+ App, the little “switch” that indicates if the S+ App is active or not beneath Burner goes to off position (switch down, Grey color). But when I leave the S+ App Menue to the Activity main page it says that many S+ Apps are activated and I get the data from Burner and the other activated App in the Activity Summary afterwards. So it is just an optical problem.
                  • EgikaE Offline
                    Egika Platinum Member @Chris Ki
                    @Chris-Ki said in How many SuuntoPlus Apps in Cycling mode?:
                    Now that you mention it this way, I remember having seen this also.
                    I am pretty sure it is solved in the upcoming update.
                    t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
