    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS offset
    Scheduled Pinned Locked Moved Suunto Vertical
    30 Posts 8 Posters 5.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • thanasisT Offline
      thanasis Bronze Member @Łukasz Szmigiel
      Hi @Łukasz-Szmigiel . Thanks for your answer .
      I am not sure of what this really means actually in terms of how to have a better outcome .
      My take is :
      I synch the watch in morning before exercising but wait 15min to unpack before starting but I will need to leave my phone at various occasions .
      Some concerns :
      • Let’s assume that I need to do that which is really not very efficient and I haven’t seen any such a suggestion anywhere else I think . (and I wasn’t doing it either with the ambit 3 peak nor with 9peak but did encounter offsets with them at times )
      • Having an offset while having a lock on the satellites is quite strange … why wouldn’t the watch indicate the lack of the gnss signal ?
      Łukasz SzmigielŁ E 2 Replies Last reply Reply Quote 0
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @thanasis
        @thanasis you can:
        • Look into the watch settings prior to your workout to confirm that the AGPS is actually valid, and with the current date;
        • Check if you’re using all GNSS systems or just GPS (you should be using all GNSS systems for the best accuracy);
        • Make sure that you’re using the best GPS settings (Performance);
        • Wait a little longer, while stationary, after achieving a fix, before hitting “Start”.
        Carrying a phone with you should have no influence on the GPS accuracy in your watch.
        @EzioAuditore, I really don’t know for sure, but as far as I understand how FusedSpeed works - this makes sense. If you want to have correct time and distance while using accelerometer alongside GPS, the recorded track would have to be influenced. I’ve seen this behavior in S5 as well.
        S9PP 2.50.28
        thanasisT 1 Reply Last reply Reply Quote 1
        • thanasisT Offline
          @Łukasz-Szmigiel ok thanks . Let’s see but the AGPs seems to be updated , I believe there is no gnss settings in the newer devices (only set up by accuracy settings which I have at best ) and I typically wait 1 minute to get a lock . Anyway I am a bit disappointed but let’s see
          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
            @thanasis said in GPS offset:
            You do this regardless of green arrow, or you wait a whole minute until green arrow appears?
            S9PP 2.50.28
            • E Offline
              enneo Bronze Member @thanasis
              Hi @thanasis, I had similar issues with the Race. It seems to me that the watch is mostly wrong on the altitude side (possibly relying too much on the barometer?) hence the triangulation is pointing in an odd location. When the data fusion algorithm is finally able to converge to the correct altitude, the position on the map gets fixed as well.
              At least this is my feeling as user, without knowing the exact implementation.
              Ambit 3
              9 Baro
              Race Ti
                Dimitrios Kanellopoulos Community Manager
                Imo. This happens when the initial fix is not well. Let it soak for gps for 2 mins.
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                EzioAuditoreE thanasisT 2 Replies Last reply Reply Quote 1
                • EzioAuditoreE Offline
                  EzioAuditore Gold Members @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos In my case I’ve tried to wait even more than 5min after the icon went green but again I had the drifts 😞 (It only got resolved after hard reset)
                  Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                  Suunto Wing
                  • thanasisT Offline
                    thanasis Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos i still think it’s something with the process i described:
                    Synch the watch (which also update the gps…), enter the activity menu in one location …. Move to a bit different place (like go down the stairs to the street) , wait 1 min (the green arrow appears) , start the activity… there is an offset…
                    I believe there is a gps fix issue as you mention which is causing it , but is that the device is trying to calculate something based on other factors and creates this offset? i don’t know but it is like a pattern to me
                    thanasisT 1 Reply Last reply Reply Quote 0
                    • thanasisT Offline
                      thanasis Bronze Member @thanasis
                      coming back to this as there is again an offset despite having a fix initially and the map showing the correct initial position… sudently it went like 15-20m to the east. What strikes me is that at the exact last point i was on track, i changed the screen visible on the watch to Zonesence
                      • thanasisT Offline
                        coming back to this as it seems it is actually related to the watch accuracy probably.
                        tried this morning with both Apple watch ultra and the vertical to check .
                        while the HR in vertical seems better (interesting!) the GPS was really flimsy at best
                        my settings are GPS best, waiting 2-3 minutes stretching after! the green arrow is set and then start exercise . The vertical in the beginning is unfortunately way out . the start point is even wrong by 25+ meters (it should be on the other side and quite closed to the stop )
                        Apple watch manages to be very close to the real path (is actually perfect)
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
