    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Textile strap on Vertical?
    Scheduled Pinned Locked Moved Suunto Vertical
    47 Posts 15 Posters 8.5k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pilleusP Offline
      pilleus @dreamer_
      @dreamer_
      A 24 mm silicone strap is another possibility. Works fine and I used the original spring bars to mount it to the Vertical.
      Blueshaweu Armband Kompatibel Für Ticwatch Pro 5, Classic Sport Silikon Ersatz Uhrenarmband Für Ticwatch Pro 5 Smartwatch https://amzn.eu/d/9dct9Lw
      https://www.instagram.com/moves.are.life/
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
      Suunto Spartan Ultra Stealth Titanium
      dreamer_D 1 Reply Last reply Reply Quote 1
      • dreamer_D Offline
        dreamer_ @pilleus
        @pilleus so the 24mm fits fine and a 26mm velcro one too. I’m probably buying the 24mm silicone strap in the same or similar color (my SV Titanium is the Sand edition)
        I have also seen 24mm velcro straps. I have a 22mm velcro strap that does seem to do the job but after your tests I’m thinking that the 24mm one is perhaps the perfect fit.
        Thanks
        Garmin Fenix 8 Solar 51mm, Suunto Run
        • thanasisT Offline
          thanasis Bronze Member @dreamer_
          @dreamer_ said in Textile strap on Vertical?:
          @halajos @isazi just to confirm that I have tried a velcro strap and the OHR has now very consistent results. The difference is so important that I’m really amazed with the results.
          Would you mind sharing Which Velcro strap ? Suunto’s or generic/oem?
          dreamer_D 1 Reply Last reply Reply Quote 0
          • dreamer_D Offline
            dreamer_ @thanasis
            @thanasis generic and very cheap
            https://a.aliexpress.com/_EuvzMH9
            It does not slip and the watch does not bounce. I’m using it with the original metal bars of the silicone straps. I’m also thinking in a wider nylon strap, sand color or similar. But for now, this one is working fine for me
            thanasisT H 2 Replies Last reply Reply Quote 0
            • thanasisT Offline
              Thank you !🙏
              • H Offline
                halajos Bronze Member @dreamer_
                @dreamer_ this one has the same kind of spring bars that Suunto straps have, I can recommend this one:
                https://www.aliexpress.com/item/1005006956566882.html?gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=8a3b9fd0-2441-4bef-8415-cf34cb7ff7ba&_t=gps-id:pcStoreJustForYou,scm-url:1007.23125.137358.0,pvid:8a3b9fd0-2441-4bef-8415-cf34cb7ff7ba,tpp_buckets:668%232846%238107%231934&pdp_npi=4%40dis!EUR!1.65!1.65!!!12.73!12.73!%40211b801917174100280778778e928d!12000038852594688!rec!FI!711197775!&spm=a2g0o.store_pc_home.smartJustForYou_2003335931081.1005006956566882
                thanasisT 1 Reply Last reply Reply Quote 1
                • thanasisT Offline
                  thanasis Bronze Member @halajos
                  Ok… i received today the two textile straps … the “green” and the blue …
                  The blue looks COMPLETELY OFF (i would call it differently )” . At best one could say it is not meant to be used on solar vertical TI version . It is immediately put into its case and ready to be sent back
                  The green is bearable but definitely not my taste. It’s like the vertical is not designed for it either but one could somehow use it for activities. I wouldn’t dare to wear if for everyday style.
                  I know this view is subjective but i think that Suunto watches are also very nicely designed and some people like myself do care about how the watch looks
                  Reverting back to the original sand type strap
                  • dreamer_D Offline
                    dreamer_ @thanasis
                    @thanasis I have that feeling but it’s more important to have valuable data in the runs than the strap. Best looking velcro straps, are probably Coros ones.
                    • A Offline
                      aligigi Bronze Member
                      I’m using the 22mm Coros strap with my S9Peak and I’m really happy with it. I think the Vertical uses the same 22mm straps. Would have bought a Suunto strap but they are not available where I live.
                      • dreamer_D Offline
                        dreamer_ @aligigi
                        Coros Pace 3’s straps seems a bit better for me, without the plastic thing that cover the metal bars.
                        Amazfit’s nylon straps look pretty nice too but Coros ones are ultralight.
                        Both brands sell the nylon straps at the same price.
                        A 1 Reply Last reply Reply Quote 0
                        • A Offline
                          aligigi Bronze Member @dreamer_
                          @dreamer_ thanks,I only knew about the model I have. I looked now and there’s a bunch of new straps from Coros. They must have launched them with the Apex3. Now I want this yellow one: https://cdn.shopify.com/s/files/1/1672/6075/products/COROS22mmNylonBand-Yellow-APEX2Pro_928x928.png?v=1716824942
                          JosaipluJ dreamer_D 2 Replies Last reply Reply Quote 1
                          • JosaipluJ Offline
                            Josaiplu Silver Members @aligigi
                            @aligigi I use it with the blue on my race
                            Looks nice 😊 not huge fan of the plastic however but it’s ok for the price
                            Old: SV, SR
                            Currently enjoying race 2, wife on SRs
                            • dreamer_D Offline
                              dreamer_ @aligigi
                              @aligigi Have a look at this strap: https://cdn.shopify.com/s/files/1/0650/2059/2396/files/PACE3NylonBand-Emma.png?v=1715369112
                              For me it looks a lot better without the plastic endings. You need to like the colour though 😁
                              • ? Offline
                                A Former User @dreamer_
                                yep the best ever! I’ve the fast lane model and it’s available right now
                                • G Online
                                  Gunnar Bronze Member
                                  Hi, I have a Suunto Spartan Ultra and I’m curious if I can use a velcro strap, e.g. the one from the Coros Apex 3 with my SSU? It seems to have a proprietary connector and I am not an experienced tinkerer.
                                  • Mouse CruiserM Offline
                                    Mouse Cruiser Bronze Member
                                    Maybe just for thought, what if you tried nylon instead of a textile belt. It fits perfectly, is easy to maintain, and there are no nasty Velcros.
                                    in bad weather, I have the original silicone strap, for longer hikes, nylon (https://www.thewatchsteward.com/22mm-straps.html)
                                    Suunto Vertical
                                    Suunto 9 Baro
                                    Suunto Spartan
                                    Suunto Ambit3 peak
                                    • A Offline
                                      aligigi Bronze Member @Mouse Cruiser
                                      @Mouse-Cruiser I hate velcro on clothes or backpacks but on the watchstrap it does not bother me, also in this case it helps getting the exact fit for the watch so for me it’s worth it.
                                      • F Offline
                                        frullewulle
                                        Hi,
                                        Do these velcro straps also helps to prevent that the sharp corner of the strap holders of the watch sometimes slightly cuts your skin on your wrist knuckle?
                                        • dreamer_D Offline
                                          dreamer_ @Guest
                                          @cjanevate . Does the fast lane have a similar texture as the texture of the black one? I had the black (an strap that weights 7g) but have not seen the other ones. I’m thinking in the Emma Bates.
                                          I hope Suunto can make similar ones. I like the Sand strap and I can’t find a similar nylon one 😀 😀
                                          And it’s a good idea. Nylon is light, It makes a good fit of the watch and helps a lot to have better WHR metrics
                                          • ? Offline
                                            @dreamer_ more or less. I chose the fast track because there’s no plastic end so it is less likely to come loose.
                                            isaziI 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
