    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Textile strap on Vertical?
    Scheduled Pinned Locked Moved Suunto Vertical
    47 Posts 15 Posters 7.9k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • thanasisT Do not disturb
      thanasis Bronze Member
      has anyone used the textile strap on vertical? (and possibly on ti version?)
      I am very much interested in SUUNTO 22MM EXPLORE 1 TEXTILE STRAP but I cannot seem to find any real world photos with the Vertical
      Thanks in advance
      BrunoHB Tami999T 2 Replies Last reply Reply Quote 1
      • BrunoHB Online
        BrunoH Gold Members @thanasis
        @thanasis said in Textile strap on Vertical?:
        One of my straps is that forest green one. It was very stiff in the beginning and the edges felt even sharp. But the more I use it the better it feels; it just takes time to break in, just like Doc Martens boots. I wear mine night and day (not the boots though).
        Compasses: M-311, A-10, SK-7
        Diving: Finnlight Navy 90, Vyper
        Sports: Metron, S7, S9B and Vertical
        • Tami999T Offline
          Tami999 Silver Members @thanasis
          @thanasis
          https://www.keskisenkello.fi/suunto-22-mm-explore-1-tekstiiliranneke-forest-green-m-l-ss050854000
          Someone has posted opinion with image 24960_84986_01599baa_6c4c_46a0_b7d4_b10d83a157e6.png
          thanasisT 1 Reply Last reply Reply Quote 1
            thanasis Bronze Member @Tami999
            @Tami999 thanks ! I am thinking of the blue version🙏
            dreamer_D 1 Reply Last reply Reply Quote 0
            • dreamer_D Offline
              dreamer_ @thanasis
              @thanasis do you know if the textile strap helps to improve OHR readings? I have tried with an unofficial one and the readings are even worse for me.
              I’m new with the SV Ti. I love this watch, it’s incredible good but the OHR is the worst OHR sensor I have had in many years (Garmin, Coros and even the latest Amazfit watches are far better when reading OHR). Despite of that this is the best watch I have ever had
              Suunto Vertical 2 Titanium Sage, Suunto Run
              sartoricS 1 Reply Last reply Reply Quote 0
              • sartoricS Offline
                sartoric Moderator @dreamer_
                @dreamer_
                Usually, for most people, it does, but it’s not 100% fail proof.
                I’m very ok with the microfiber one.
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.10.7 beta
                  thanasis Bronze Member @sartoric
                  @sartoric said in Textile strap on Vertical?:
                  @dreamer_
                  I am using the microfiber on non sports-related activities but it gets wet and smelly quite easily
                  I have ordered the textile one and waiting for it. Will report when i receive it
                  • sartoricS Offline
                    sartoric Moderator @thanasis
                    well, wash it 😁
                    SVTS - 2.50.28
                    • cosme.costaC Offline
                      cosme.costa
                      I do not have any textile strap but I think the important part is the closing system to improve the OHR. I mean if you use a textile strap with hook and holes it is the same as a silicone one, but if the closing is velcro it should help the OHR because you can do a more accurate adjustment.
                      I’ve been tempted to buy the Coros velcro strap, that looks compatible with the SV/SR and it is cheaper than the Suunto’s straps.
                      ? dreamer_D 2 Replies Last reply Reply Quote 0
                      • ? Offline
                        A Former User @cosme.costa
                        @cosme-costa said in Textile strap on Vertical?:
                        the thinnest I’ve ever tried, cheaper but very good, you will not be disappointed at all!
                        • dreamer_D Offline
                          dreamer_ @cosme.costa
                          @cosme-costa I had the Pace 3 and the Coros Pace 3 nylon strap is the best and lightest strap I’ve ever tried.
                          As far as I understand, It should be compatable.
                          H 1 Reply Last reply Reply Quote 1
                          • H Offline
                            halajos Bronze Member @dreamer_
                            I have good experience with this cheap velcro strap.
                            Wrist HR is quite good when using this strap, tightened enough. I even ran intervals with it with good results. But on trails, when using poles to climb or bouncing heavily downhill, HR values are off.
                            • dreamer_D Offline
                              dreamer_ @halajos
                              @halajos Thanks a lot. I have also noticed that the worst OHR data I get is while trail running. I have the feeling that the watch bounces a lot with the original strap. The original strap is very comfortable but the SV Ti is a big watch with 74g.
                              @pilleus I have seen these 2 threads where you have much better OHR results with the velcro strap, specially the feeedback talking about the 26mm one:
                              https://forum.suunto.com/topic/9172/ohr-sensor-often-good-but-why-sometimes-not/30
                              https://forum.suunto.com/topic/10627/topic-to-digress-for-this-and-that/15
                              Really interesting information. I will also try to fit a 26mm one. Seems a very good (and cheap) solution
                              H pilleusP 2 Replies Last reply Reply Quote 1
                              • H Offline
                                @dreamer_ silicone tends to slip a lot when wet, impacting HR readings.
                                dreamer_D 1 Reply Last reply Reply Quote 2
                                • dreamer_D Offline
                                  dreamer_ @halajos
                                  @halajos true. I also remember that the watch was sliping with the original strap in the run I was talking about.
                                  Excited to know that there’s perhaps a good (and instant fix)
                                  H 1 Reply Last reply Reply Quote 0
                                  • H Offline
                                    @dreamer_ the velcro strap I’m using slips much less, especially if it’s tightened well.
                                    dreamer_D 1 Reply Last reply Reply Quote 1
                                    • dreamer_D Offline
                                      dreamer_ @halajos
                                      @halajos thanks a lot! I’m going to buy that strap too 👍 😊
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • isaziI Offline
                                        isazi Moderator @dreamer_
                                        @dreamer_ velcro made even the S9B behave better, I only wish Suunto would still make them.
                                        Blog: isazi's home
                                        H 1 Reply Last reply Reply Quote 4
                                        • H Offline
                                          halajos Bronze Member @isazi
                                          @isazi yes, I bought a 3rd party velcro strap for the S9B and WHR improved a lot.
                                          • dreamer_D Offline
                                            dreamer_ @halajos
                                            @halajos @isazi just to confirm that I have tried a velcro strap and the OHR has now very consistent results. The difference is so important that I’m really amazed with the results.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
