    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Navigation And Route Recording
    5 Posts 4 Posters 597 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      JohnC120
      I am a new user and have a couple of questions.
      1. Is it possible to navigate a route on the watch AND record the route at the same time? If so, how?
      2. While navigating a route is it possible to see:-
        a) the current time; and b) the current distance travelled; and c) current altitude?
      When navigating I am currently stuck on the navigation screen.
      Thanks.
      sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @JohnC120
        @JohnC120
        You just need to start an activity with a route to follow
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.8.9 beta
        J 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @JohnC120
          @JohnC120 said in Navigation And Route Recording:
          Thanks.
          a) you will see the time at the top of most screens but not the map screen
          b) this is a field on most standard sport modes or you can make a custom mode but not on the map screen.
          c) depends on the sport mode and not on the map screen.
          Vector/T6c/Vertical 2 Ti
          • J Offline
            JohnC120 @sartoric
            @sartoric
            Thanks.
            May I then switch between the 2 modes?
            AudaxjoeA 1 Reply Last reply Reply Quote 0
            • AudaxjoeA Offline
              Audaxjoe @JohnC120
              @JohnC120 you don’t need to switch modes to see what you want, you only need to rotate between screens.
              My set up is.
              First Screen basically distance
              Second Screen Distance to next waypoint
              Third screen distance to end
              Then forth screen is breadcrumb (no map, but easy to follow) then altitude profile
              You can then move between the screens.
              This is very simplified I have other data like altitude ETA ect which you can program what is important to you. And you can choose how many fields you have in each screen except the breadcrumb and altitude profile.
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
              • First post
                Last post
              Suunto Terms | Privacy Policy
