    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SuuntoApp - Loop Pace - I can not make it work...
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    suuntoplus loop
    16 Posts 5 Posters 3.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mklbhmM Offline
      mklbhm
      I don’t know what I’m doing wrong…
      I have installed the SuuntoApp Loop Pace on the watch.
      Activated it before I started my run.
      On the SuuntoApp screen I pressed the lower button where my lap starts.
      Got the message “Set start location”.
      Went several laps but it still said Loop 1 on the S+ screen.
      Have also tried to hit the lower button to make a manual lap and then, on SuuntoApp screen, hit the lower button.
      I have a S9 Peak Pro. Firmware 2.33.12.
      I have uninstalled the SuuntoApp app and reinstalled it. I restarted the watch after uninstall.
      HELP! 😵
      W 1 Reply Last reply Reply Quote 0
      • W Offline
        Wilson75
        I agree. The app doesn’t work anymore. I used speed and power. As you described the watch remains at loop 1.
        I hope it will be fixed
        Suunto Vertical Titanium
        Suunto Wing
        SA (bêta) on Pixel 9pro
        S9B Titanium (sold)
        SSU (sold)
        T 1 Reply Last reply Reply Quote 0
        • T Offline
          The_77 Silver Members @Wilson75
          @Wilson75 I’ve used it two weeks in a row on the track and it has worked exactly as I expected, one loop every time I cross the point I determined as the loop start with the lap button.
          Maybe something else going on? Be weird for it to work on 9PP and not vertical.
          Suunto Spartan Trainer Wrist HR / 9PP Refurb
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @The_77
            @The_77 works fine on Vertical for me.
            Blog: isazi's home
            • Raimo JärviR Offline
              Raimo Järvi
              I don’t think it’s likely to be a problem specific to S9 Peak Pro or the firmware version. What kind of speed were you running, and what were your exercise settings, for example navigation and battery mode settings? What kind of loop were you running?
              Pragmatic Programmer
              W 1 Reply Last reply Reply Quote 1
              • W Offline
                Wilson75 @Raimo Järvi
                @Raimo-Järvi
                I used custom cycling mode with the following settings :
                • Battery mode : custom (best accurancy/ touch screen ON)
                • Pairing : Power device / HR belt
                • S+ : Multiple -> 2 S+ apps (Power and speed loop)
                • Navigation
                Suunto Wing
                S9B Titanium (sold)
                SSU (sold)
                Raimo JärviR 1 Reply Last reply Reply Quote 0
                  Raimo Järvi @Wilson75
                  @Wilson75 OK, thank you. Which Navigation setting did you use? Using two loop apps at the same time may not produce good results, at least they will both create a separate lap when loop ends. I’m not sure if using two loop apps at the same time also affects loop detection, I’ll try to test it.
                  • W Offline
                    @Raimo-Järvi I walked today with custom sport mode.
                    S+ : 1 app used - loop pace
                    Battery mode : custom - best GPS / touch screen activated
                    Navigation : breadcrumb
                    And lap didn’t work…
                    Strenge
                    Suunto Wing
                    S9B Titanium (sold)
                    SSU (sold)
                    • W Offline
                      Wilson75 @mklbhm
                      @mklbhm are you able to use S+ Loop?
                      I tried again after the last firmware (Q2) and it still does not work…
                      Suunto Wing
                      S9B Titanium (sold)
                      SSU (sold)
                      • isaziI Offline
                        isazi Moderator @Wilson75
                        @Wilson75 can you describe again how you use it?
                        Blog: isazi's home
                        • W Offline
                          Wilson75 @isazi
                          @isazi
                          I use walk activity (not custom) and suunto plus Loop Pace.
                          I simply launch my activity.
                          I tried once without pressing the lap button and got no loop detection.
                          I also tried pressing the lap button to set a new location for my loop and no loop detection either.
                          Suunto Wing
                          S9B Titanium (sold)
                          SSU (sold)
                          • isaziI Offline
                            @Wilson75 did you press the lap button on any screen, or the app screen? It only works in the app screen as far as I know.
                            Blog: isazi's home
                            • W Offline
                              Wilson75 @isazi
                              @isazi Yes in the app screen. I also get the message from the app screen that I set a new location for the loop.
                              Suunto Wing
                              S9B Titanium (sold)
                              SSU (sold)
                              • isaziI Offline
                                @Wilson75 can you try with a running activity?
                                Blog: isazi's home
                                • W Offline
                                  Wilson75 @isazi
                                  @isazi I tried with run and cycling. I can try again and I will let you know.
                                  Suunto Wing
                                  S9B Titanium (sold)
                                  SSU (sold)
                                  • isaziI Offline
                                    @Wilson75 I use the app every week, always worked for me, I do not know what could be wrong
                                    Blog: isazi's home
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
